Important Locker Bypass Question for Future kits
myoung84
Post by myoung84 » Tue Jun 03, 2014 9:37 am
Got a question for you guys. Do you have an issue with adjusting the relays yourself on future kits? I used to use my truck to adjust them but it's gone now. I'm sure I could build a small box to simulate the selector knob but it would be much simpler to just have you guys do it. It's very simple, just turn the knob to rear, adjust relay 1 until it trips, turn knob to front/rear, adjust relay 2 until it trips, then put the cover on the box. That's it.
Is this something that you guys would be good with?
SheepdogOutdoorsman
Re: Important Locker Bypass Question for Future kits
Post by SheepdogOutdoorsman » Tue Jun 03, 2014 10:54 am
I guess as long as there are detailed instructions contained within the materials. I wouldn't have a problem with it.
chad13powerwagon
Post by chad13powerwagon » Tue Jun 03, 2014 11:01 am
i would be ok with that as long as i get detailed instructions as well
thanks
13 Power Wagon
Vararam air grabber, Moe's performance 87mm throttle body in tune with hemifever tune
stubiePW
Post by stubiePW » Tue Jun 03, 2014 11:20 am
I'm cool with it. Instructions? We don't need no stinking instructions. Well, probabaly
myoung84
Post by myoung84 » Tue Jun 03, 2014 11:46 am
Sweet! I'll definitely have detailed instructions!
Post by Will » Tue Jun 03, 2014 12:49 pm
He just gave the instructions, "turn it until it trips" :lol:
Post by adeluca73 » Tue Jun 03, 2014 1:15 pm
I can adjust it too. Question, is the relay adjustment a set screw in the low voltage end of the contactor, that requires taking off the housing to access or are these fancy relays with external rheostat knobs?
myoung84
Post by myoung84 » Tue Jun 03, 2014 1:57 pm
adeluca73 wrote:I can adjust it too. Question, is the relay adjustment a set screw in the low voltage end of the contactor, that requires taking off the housing to access or are these fancy relays with external rheostat knobs?
It's a surface mount pot, very easy to get to. Just need a small screwdriver.
Post by adeluca73 » Tue Jun 03, 2014 2:02 pm
Copy--should be no issue then
Post by adeluca73 » Tue Jun 03, 2014 2:06 pm
ACRucrazy
Post by ACRucrazy » Tue Jun 03, 2014 7:01 pm
Gen 3?
‘17 AEV Prospector XL
‘06 RCLB Laramie - Gone
bajaben48
Post by bajaben48 » Fri Jun 06, 2014 7:21 am
Not hard at all.
sent from a deep hole know only in fabels
Ben
Us Army EOD
Joe Cool
Post by Joe Cool » Wed Jun 11, 2014 1:45 pm
I'd be good with adjusting the relays.
2013 Copperhead Pear Power Wagon Laramie. 2" Levelling Kit, dual exhaust, Wireless WARN winch remote, myoung's very cool Locker bypass Kit.
wyohunter
Post by wyohunter » Thu Jun 12, 2014 4:07 pm
Howdy-I sent a message to your vendor address myoung84 about buying this for my soon to arrive 2014. let me know-thanks.
Pwagon12
Post by Pwagon12 » Sat Jun 14, 2014 11:44 pm
MYOUNG84 thought I was on your list along time ago. don't know what happened but would still like to have one thanks
2012 power wagon, bt oil catch can, S&B cold air intake
