I think that is way to much weight for a power wagon.... Especially dry weight. Add your 6" lift to the equation and it is flat out dangerous. Pulling it is gonna be very difficult but still not the main issue. The tail will be waging the dog. Having control of the trailer is gonna be impossible to do safely. I sure don't wanna be near ya on the road... That's for sure.Hemi46 wrote:I am looking into buying a fw toy hauler rated at 13050. That's dry weight. I think our trucks can pull it, like Firerescue said. Looking to see the comments on this.
The 2.5 " receiver on the pw is rated at 17000 lbs pull/ tongue?likely around 1700 lbs. My WD hitch is rated at 10000 pull/ 1000 lbs tongue. When it scale it this spring I'll determine if I need to upgrade my hitch to something beefier based on my tongue weight.wagonfarmer wrote:One concern I have is with the 9400 lb bumper pull trailer. I could be wrong, but am pretty sure there are no hitches made for our trucks rated to pull that much weight unless you with a 5th wheel or goose neck.
With my 2011 I tow a 30' (hitch to bumper) travel trailer that is 6500lbs dry and around 8,000lbs fully loaded. On some camping trips I also have my quad, my kids mini quad, a generator, extra fuel, chainsaw and other stuff all loaded in my bed. Like Twinstick I have the Hellwig's.R0NAN wrote:I also am mildly concerned as I have a toy hauler that is about 9500 lbs completely loaded. The plan is to get some carli air bags. The quads load on a deck at the front of the trailer. The tongue weight dry is 650lbs and I'm not sure about loaded. The water and fuel are at the back so I'm hoping it helps balance out the weight of the quads.I guess I'll find out when I get my trailer out of storage and scale it. The equalizer hitch should help and I may have to get the trailer sway bar... Although I didn't seem to need the sway bar with my last truck.
1: Can anyone chime in on how effective the tow haul mode is with the power wagons gas engine?
Also, I wanted to use my tekonsha p3 brake controller but can't seem to locate one of the plugs under the dash. Wiring for brake controllers changed in '13 and the video for '13 tekonsha install is for rams without the oem controller, which I have. I think that is why I can't find the missing plug. So I plan on selling it and use the controller that came with it..... Which leads me to this question. 2: How does the oem brake controller work in the power wagon? Are any of you dissatisfied with its performance? The tekonsha p3 is beautiful as it has a boost feature which activates the trailer brakes just ahead of the truck brakes which is nice for heavy hauling.
R0NAN wrote:The 2.5 " receiver on the pw is rated at 17000 lbs pull/ tongue?likely around 1700 lbs. My WD hitch is rated at 10000 pull/ 1000 lbs tongue. When it scale it this spring I'll determine if I need to upgrade my hitch to something beefier based on my tongue weight.wagonfarmer wrote:One concern I have is with the 9400 lb bumper pull trailer. I could be wrong, but am pretty sure there are no hitches made for our trucks rated to pull that much weight unless you with a 5th wheel or goose neck.
The limiting factor on power wagons is the off road suspension... Otherwise it would be the same or similar to other hd 2500's.
