Traction Control
Traction Control
Hey, I am new to this forum and wondering if there is any modification to shut traction control completely off for good..I am so sick of it on a 4WD truck!! HELP!!!
- SheepdogOutdoorsman
Re: Traction Control
Hold the traction control button down for 10 seconds ... It disables the system ... Or just pull the fuse
It does not fully disable the system, at least not on 2013's. It may say it's off, just like it does in 4lo, but it's not.SheepdogOutdoorsman wrote:Hold the traction control button down for 10 seconds ... It disables the system ... Or just pull the fuse
Yeah, I've heard that ... I haven't had a chance to try it out myself, but I've heard pulling the ABS fuse does the trick
For 2012 and newer you can't shut it down 100%. The fuse pull might be the way to go.SheepdogOutdoorsman wrote:Yeah, I've heard that ... I haven't had a chance to try it out myself, but I've heard pulling the ABS fuse does the trick
Myoungs smartbar bypass locker kit = traction control!
