Airing down how low?
- chromedragon
Hello everyone,
I am getting further and further into wandering into the back woods areas of Cali. One of the trip reports to an area i want to explore noted that they aired down there tires for the area in question. The trucks being used were Toyota Taco's and Mitsubishi Monteros.
My question is how low do any of you run your tires when out exploring in back country areas. The manual says down to 15 psi but that scares me with my normal operating load in the 60-70 range.
Can any one comment on your experience. i'm just making sure i don't end up in the back woods with a poped bead on a tire. I know the wheels i have don't have bead locks.
For reference im running Cooper Discover ATP tires LT285/70R17E1 121S W
any feed back would be welcome
Tony
Tony
Special Licenses:
FAA Airframe and Power Plant
FCC Technician (Ham) KK6YCI
Robert A. Heinlein
Special Licenses:
Robert A. Heinlein
- Cactus Red
Re: Airing down how low?
I start at 25 PSI, and adjust lower as needed. I've gone as low as 10 PSI, but you stand a pretty good chance of losing the bead at that - I have even with the stock PW rims.
The ride and traction greatly improve at 25 PSI or so, but fuel economy take a pretty substantial hit, and going lower only makes that worse. I usually see 9 to 10 MPG in the 22 to 25 PSI range, if you get into the teens, figure 6 to 8 MPG.
The 12 hour day trip I took two weekends ago used 23 gallons of gas in 170+ miles, and that was with tires in the 20 PSI range. I've seen the overhead show 4 or 5 MPG in snow or sand.
Mark
Mark
I go down to about 13 up front and 11 in the rear. I'm on 37x12.50R17 MTRKs though. With stock tires I wouldn't go below 25psi because I needed all the ground clearance I could get!!! On a funny note- time before last that I went wheeling, I didn't air down at all (was being lazy) then, this past time, I aired down to 12[F]/10[R] and kept catching the top 1" of rocks on the trail repeatedly! (just the 1" of clearance I lost by airing down, LOL!) Pay attention to your new (lower) clearance when you air down!
On Borad Air........... 20 max for me, even though the PW does have a better Rim, for this, if you do not ahve On-board air, or not with those who do, be cautious, even 30 is better than 60 or 45...
2006 Power Wagon
5th Wheel hitch
5th Wheel hitch
With 35" tires 20 psi front/rear is what I run with a fully loaded truck on multi-day trips out in the desert (rocks, sand, snow, mud, hard-packed dirt roads, etc.) it seems to work real well. With an empty truck in really soft sand you could go lower maybe 10-15 psi but I never have needed too.
I run about a half pound less in the right rear to increase forward bite comin out of the corners.
I could have sworn it was a pound and a half less and was to help keep traction through the corner.fbenross wrote:I run about a half pound less in the right rear to increase forward bite comin out of the corners.
How low a pressure you can run really depends on the kind of 'wheeling you do, and your driving habits. I've gone as low as 5psi, but that is in the winter when there's little traction to be found...plus, I normally drive very slowly off-road. If you're the kind of guy who drives full-throttle, sliding sideways most of the time, I would stay at least up in the 20-25psi range. Actually, I'd probably go 25 psi just to be safe...I haven't lost a bead at that pressure yet, even doing some pretty hairy maneuvers at 70+ mph on the fire roads. You do lose a lot of clearance at the really low pressures, but depending on the terrain the added traction is well worth it. I air down a lot in snow or sand, but not as much in mud and packed dirt.
I have some friends who don't bother to air down, because they don't want to take the time to air back up - and in some situations I can get around better in two wheel drive than they can in four wheel drive...it can really make that much of a difference. There's a local hill around here that (as far as I know) my Power Wagon is the only truck that has been able to climb...but it wasn't good driving on my part, I just aired all the tires down to 5psi and crawled up it with the lockers engaged. Everyone else was hitting the hill at high speed and trying to make it up with momentum, but with the tires nearly flat I was able to use traction to make it to the top.
Sometimes airing down feels like cheating.
- stamm20
I ran mine at 12psi in the sand an had no problems with it
- chromedragon
thank you all for the information. I can now go work with the tools and compressor to make sure i can air up and down on the trail before i get there
Special Licenses:
Robert A. Heinlein
Special Licenses:
Robert A. Heinlein
2006 Power Wagon
5th Wheel hitch
5th Wheel hitch
- whitey
I agree with all the above but the tire and the weight on each tire make a difference too. I am on sharp obstacles a lot so I make sure my tire can mold around the object without puncture but not so much that I loose too much clearance or pinch the tire hitting obstacles. I have a CO2 tank so I adjust on the fly. If I'm not getting the clearance I need then I go up a few pounds and I go down for traction. some brands I go down to 22lbs and some down to 27. Sand I go a lot lower, from 15 to 22 depending on the tire. I just picked up my 5th set of tires 10 days ago so I'm discovering what to do with em myself.
This is what I use to air up or run air tools. Super - quality and reliability and it's portable.
- HammerTime
- Model Year: 2017
In the sand dunes I've gone as low as 10 PSI with my Power Wagon, never lost a bead yet. (I have a few times on my Rubicon, but I take it down to 6/7 PSI.) So far I've been lucky, my air compressor has always been able to reseat my tires after blowing the seal.
2017 White/Black Power Wagon
Rich
2008 PW
White Knuckle rock rails, 5100 Bilstein 2-3", 5100 Bilstein front stabilizer, Super chip.
- whitey
Actually the powertank works really well. CO2 goes into a liquid under pressure so its volume is deceiving. I don't think there's anything else that can air up a large tire as quick as a powertank. The negative is you need to know where to get it charged.
- Cactus Red
And cost per tire is really high with a CO2 system. I got roughly 24 tires per tank, at $18.00 per refill. Cost for the system is high too compared to an MV50 12v compressor. A CO2 setup will reseat a bead, but so will most compressors if used with a large ratchet strap around the tire and a can of foaming window cleaner to slick up the bead. That works pretty much 100% if only one bead is broken.
Sent via gigawatt laser...
I usually air down to about 20 PSI, depending on where I am going. Here's a little piece of gear that I've really liked for a lot of different reasons.
http://www.cloreautomotive.com/sku.php?id=245
It's a jump starter, 12v power source (nice for camping), and it's got a pretty nice built-in air compressor. The nice part is that it fits into my swing case, so it's not bouncing around somewhere in the truck. They're a little pricey compared to the jump packs you can find at Walmart or whatever, but they're professional quality.
When I ran my TJ Rubicon on tons and 40's I always used a CO2 tank, but that's because those tires took quite a bit to re-inflate when coming from 2PSI (beadlocks). For most uses, the jump pack with air compressor is more than you need and it's a bit faster than a lot of those cheap 12v pumps. The only downside is that you can't really power air tools with it.
Before writing this post, I'd like to say that I just took a bunch of painkillers for a back problem...so I cannot be held responsible for anything I say.
Airing back up is something I've messed with quite a bit over the years, and it's one of those things where there really isn't any 'best' way to do it. Basically, your options are easy, fast, or cheap...and you can only ever have two out of the three.
The high-pressure tanks are easy and fast, but they tend to be a bit pricey if you 'wheel a lot. If you want cheap and easy you can get one of the small MV-50 type compressors, which'll do the job but not very quickly. Plus, they tend to have a few 'quirks' and you might have to deal with on/off switches that stick, or oddball connectors, or things like that. For the most part, the cheaper compressors tend to be slower and need more maintenance, but since they're really simple devices it isn't a big deal. I've got one of the MV50s, plus I bought a Viair 70P about a year ago...the MV50 is a bit faster, but the Viair 70P seems to be higher quality.
Another option - if you have a large shop air compressor at home - is to just take a large portable air tank with you when you leave on a off-roading trip. It doesn't take long to fill it with a big compressor, and it'll hold enough air to pump your tires up to a 'safe' pressure for driving on the road. I did that for a long time, because it's faster than a portable air compressor and more reliable. A single 10-gallon tank was usually enough to air up the tires to drive on the road, though if I was going to drive higher speeds or longer distances I'd probably want to have 2 10-gallon tanks (one for each end). However, this only works for adding 10-20 pounds of air to each tire...if you air down to 10psi and want to go back up to 60psi you'll either need a powertank or a compressor (and a lot of patience).
Since my truck is really only used off-road, I've stopped even bothering to air back up - I just keep the speeds down to 45 mph or so on the way to and from the trail. I can get away with that around here since none of the roads have a higher than 55 mph speed limit, and our traffic is nearly non-existent - it isn't unusual not to see a single vehicle on the way out to the trail. If I lived in a place with more people, I'd have to figure something else out so that I didn't hold up traffic. Now instead of airing down for the trails, I keep the tires aired down and only air them up when I need to pull a trailer or haul a heavy load.
VERY well said LKelly !
This magical place that you speak of (no other vehicles & non-existant traffic & people)...........It's the Big Rock Candy Mountain, isn't it ??????
Thanks...most of my best writing is when I'm highly medicated.TwinStick wrote:VERY well said LKelly !![]()
TwinStick wrote:This magical place that you speak of (no other vehicles & non-existant traffic & people)...........It's the Big Rock Candy Mountain, isn't it ??????
I went down to 12 ish PSI after getting stuck (with a 16' trailer") is super deep sand. Worked like a charm. I also have the deflators which is nice! The military ones are the best ones IMHO. Took FOREVER to refill tires though with small portable compressor . Now I have a badass onboard air system. Worth every penny..
Do tell about these military deflators. Where would one procure said devices?
