Long story short, on a 'wheeling trip I ended up on the wrong side of a trench that was about 4 feet wide and 3+ feet deep - and needed to get across it to get back to civilization. It had been a long and frustrating day and was after dark, so I just decided that if I hit the trench with enough speed I'd sort of skip across the top of it without falling in - and yes, I realized that it would be really hard on the truck to do that. Anyway, it worked (more or less) though it was rough enough that it knocked out a taillight and threw everything around the cab...even my magnetic GPS antenna and phone antenna came off, which is the first time that'd ever happened without actually hitting something. I figure there's about a 50/50 chance I damaged the front axle, but I knew that risk when I did it.
Anyway, after the fact I realized that I should have disconnected the airbags...though luckily they didn't go off. That got me wondering - I often pull the fuse to disable the ABS when I'm out wheeling, but I don't normally pull the airbag fuse. Does anyone here normally do that? I'm thinking I might start in the future.
Also, through my misadventures that day I not only lost a taillight, I bent my brushguard, mangled a rear fender, and was having problems with the charging system (which was hopefully just snow on the belt). I also found the only mud around in mid-January (considering it's well below freezing) and the entire front of the truck is coated in mud. Does anyone have any tips for getting mud off a truck when it's only 10 or 20 degrees out? In the past I've gone to a carwash that had heated water, but the truck still freezes up afterwards and it seems like I spend the rest of the winter battling with it. I'm wondering if there's something I can spray it with to remove the mud, but that has a lower freezing point than water...maybe RV antifreeze? I've never put that on painted surfaces, though...it'd be a bummer if it took all the paint off.
I used a spray bottle filled with the deicing windshield washer fluid to wash the mud off the side windows, but it'd be a little pricey to use that to wash the whole truck.
My friends pointed out that I'm the only person who could find mud when the ground's frozen solid and the lakes have enough ice that people are driving on them.
My lessons for the week are to avoid mud in the middle of winter, and don't try to jump a PW over stuff unless you have a take-off ramp.
