New massive recall of 1.2M Ram trucks....
New massive recall affecting all 2500 and 3500 Ram trucks made after 2003 for steering failures, to likely begin in January.
http://media.chrysler.com/newsrelease.d ... 5075&mid=1
ScottWagon1
Re: New massive recall of 1.2M Ram trucks....
Hurry up and wait.
well i'm glad I haven't modded my 2006 front end at ALL...cuz they will fuck with you if you have !!!
I thought I had my "inspection" recall done a year ago.. Is this the same one?
X2 ... (insert 2005)fbenross wrote:well i'm glad I haven't modded my 2006 front end at ALL...cuz they will fuck with you if you have !!!
It doesn't mention the 2013 model year, so hopefully I won't have to hear anything about all the carli parts up front.
This recall will not be denied if the truck has been modified. This recall is about removing and replacing earlier and potentially defective revisions of steering linkage parts. In laymen's terms it means that it doesn't matter if the truck was original or modified so long as the linkage has not been modified(meaning the linkage itself has not been cut or welded on as an example). This recall is about a safety issue with earlier revisions of the steering linkage.
The newer linkage has a pin or key to align the ends of the linkage to prevent limitations in motion that can cause failure of the tie rod end(TRE).
From what I gather in the recall is that, all of the trucks that have a "T" style linkage with an early revision will be replaced free of charge.
sent from my telegraph using Tapatalk too!
I can 't believe they waited this long....bet they hoped most were out of service by now...at least the 05's I guess.
i got a recall about a year ago on the tie rod ends..dealer checked it..was fine…is this another recall?
- bstefanic
When I put my new ball joints in my TRE was shot, glad I paid for a new one myself...Pit Slave wrote:This recall will not be denied if the truck has been modified. This recall is about removing and replacing earlier and potentially defective revisions of steering linkage parts. In laymen's terms it means that it doesn't matter if the truck was original or modified so long as the linkage has not been modified(meaning the linkage itself has not been cut or welded on as an example). This recall is about a safety issue with earlier revisions of the steering linkage.
I got my recall notice today in the mail for 2008-20012 models for front left tie rod fracture and failure. My truck is going in for other work monday to the dealer. I will let you guys know how I make out. This is the second recall I have had to take to the dealer.
. Even if they repair it, it will fail in the future due to oem junk.
Got mine in the mail yesterday. Gotta find time to take it in. Does this include an alignment as well?
The Jeep has a recall too that I've had for a couple months to reflash the computer. What a pain.
I'm not sure, I would think so if the parts are changed. An alignment would be needed. I'll let you know Monday evening how I make out. Nice work MyYoung84 on locker harness!
I 'm interested in one in the future. Are the relays replacable if on fails. A plug style?
Check out the thread link below for some pics of inside the box. The relays are replaceable if necessary. They are glued to the inside of the box with Goop, which holds them very well but also makes them removable with a little effort. I experimented with a few different adhesives and this was the best compromise of strength and remove-ability...pasparky wrote:I'm not sure, I would think so if the parts are changed. An alignment would be needed. I'll let you know Monday evening how I make out. Nice work MyYoung84 on locker harness!I 'm interested in one in the future. Are the relays replacable if on fails. A plug style?
http://forum.powerwagonregistry.org/vie ... =22&t=1679
wingerak92
Seeing as I don't have a garage… I took my truck in for its 52,000km service last weekend and they made a point to mention to me there is no outstanding recall on my truck!
Sorry myYoung84> lol I should looked into pics more. great job. I should of posted on another thread, lol I'm still learning how to use forum. btw your looks great
mines still stock for now. you guys are giving me all sorts of ideas,
No worries! My locker bypass threads have gotten crazy. Thanks for the kind words! You hang around here long enough and you'll go broke very quickly!pasparky wrote:Sorry myYoung84> lol I should looked into pics more. great job. I should of posted on another thread, lol I'm still learning how to use forum. btw your looks greatmines still stock for now. you guys are giving me all sorts of ideas,
Got my recall the other day. My work schedule changed, and now I have to find time to get it done.
Had An appointment for warrantry repairs today for 3yr/36000 mile- new heater blower on order and two axle joint installed at 35000 miles. As for the steering recall they said I was on recall list but will schedule it in mid January due to the repair is not allowed to be done til then which is earlyist Chrysler allows the rapair to be done. No alignment is included just minor toe adjustment.idk. I'll keep everyone posted on my experiance
Got my recall notice in the mail a couple days ago.
2023 Power Wagon
Previous Truck
Previous Truck
No alignment included is BS. Does the warranty cover premature tire wear from bad alignment?pasparky wrote:Had An appointment for warrantry repairs today for 3yr/36000 mile- new heater blower on order and two axle joint installed at 35000 miles. As for the steering recall they said I was on recall list but will schedule it in mid January due to the repair is not allowed to be done til then which is earlyist Chrysler allows the rapair to be done. No alignment is included just minor toe adjustment.idk. I'll keep everyone posted on my experiance
- MOPARManiac
Got my letter in the mail yesterday. It said that I can't schedule until after January 8, 2014. My front pinion seal is leaking so I will probably get it replaced as well. See how that Maxcare Lifetime warranty works with $100 deductible.
- GunniPWguy
Got my recall notice in the mail. Wondering if this was resolved when I had the new T-steering installed a couple years ago?
From the description, it may have been CAUSED by us having T-style steering installed before they added the alignment pin and fork where the tie rod end meets the tie rod. The problem is potential misalignment between the two, taking away any available rotation during the steering cycle. I'm in the same boat. Thought I was doing well replacing the Y-style. Oh well. New parts again.GunniPWguy wrote:Got my recall notice in the mail. Wondering if this was resolved when I had the new T-steering installed a couple years ago?
I made it a point to make sure my tie rod ends where both aligned evenly so I'm not in a big rush to get the recall done.
