Warn wireless winch remote
Ducky's Dad
Re: Warn wireless winch remote
Post by Ducky's Dad » Tue Aug 20, 2013 11:34 pm
I have not yet received mine, but I'll probably fill the plug with silicone grease and leave it in place.
myoung84
Post by myoung84 » Tue Aug 20, 2013 11:43 pm
I'd apply a generous dose of dielectric grease and call it good.
Cactus Red
Post by Cactus Red » Wed Aug 21, 2013 10:48 am
After three years, you inquiry made me take a look at mine. It's been plugged in the whole time, and has always worked fine. It was dirty as heck tho, so I went ahead and cleaned it up with contact cleaner and capped off both ends.
azracer
Post by azracer » Wed Aug 21, 2013 2:01 pm
Mine was the same plug.
I just used Dow 111 silicone grease to keep water out and left it plugged in.
Dow 111 is a very thick lubricant and does not harden at all ever.
Mine will never be submerged (on purpose anyway) but will get splashed.
The back of the plug is exposed to the elements so even with a tight fitting remote plug water would enter.
http://www.amazon.com/DOW-111-Lubricant ... ds=dow+111
Post by RustyPW » Thu Aug 22, 2013 5:15 am
With the grease. Just keep pushing it into the holes in the plug until you think it's coming out of the back of it. Then push alittle more into it just to be sure. :wink:
Original_Junior
Post by Original_Junior » Tue Aug 27, 2013 6:11 pm
azracer wrote:Mine was the same plug.
Is this better than using di-electric grease? Is this stuff like hitch ball grease?
2007 Power Wagon, Quad Cab, Patriot Blue
Mods Complete: Line-X, Amp Research powered steps, Aero 3030 dumped, UWS red series toolbox, tinted front windows, Line-Xed Randy Ellis Light Bar, 315 Good Year DuraTracs on H2 wheels, Line-X rockers, AFE Dry Flow filter, Lightforce 240's & 170's front & Hella work lights rear
Mods to Come: Aeroforce & SRT grab handle, headache rack
Post by RustyPW » Thu Aug 29, 2013 5:17 am
The Dow Corning 111is o-ring lube. Use this stuff by the tub at work.
azracer
Post by azracer » Thu Aug 29, 2013 11:27 am
Yes Dow #111 is quite a bit thicker and has a much higher melting point than Dow #4 dielectric grease. It also can't be splashed or sprayed off... Well other than with a steam cleaner that is. :excited:
Post by RustyPW » Thu Aug 29, 2013 8:09 pm
azracer wrote:Yes Dow #111 is quite a bit thicker and has a much higher melting point than Dow #4 dielectric grease. It also can't be splashed or sprayed off... Well other than with a steam cleaner that is. :excited:
Yea, and you really have to scrub your hands good too. To get the stuff off. Otherwise your hands are slick for awhile. :lol:
Post by FirerescuePW » Fri Aug 30, 2013 9:51 am
Some may like that...
Sent from my SPH-L720 using Tapatalk 4
myoung84
Post by myoung84 » Fri Aug 30, 2013 11:37 am
Could come in handy... No pun intended... :D
stubiePW
Post by stubiePW » Sun Sep 01, 2013 11:40 am
I just put my bid in. The user is out until Sept. 3rd, but we'll see. Figured I should do something to the Wagon!
