Tire pressure monitors
I switched the stock 33” Duratracs to 35” Wrangler Boulder MT’s. Definitely not as smooth on the road as the Duratracs so I want to lower the tire pressure. Sounds like most people suggest 40/45 psi. I know that will throw a warning. My question is can I just leave light on and ignore it or do I need to buy some type of programmer? I have looked at the AEV Procal, Alfa OBD and the Tazr. All of them require pulling off panels to get to sensors. Wish there was a plug and play programmer like the Hypertech one I had years ago. Maybe I just need to ignore the tire pressure warning light!
Re: Tire pressure monitors
Sorry I posted this multiple times!
2024 Tradesman w/ Power Wagon package Black on Black
35” Goodyear Wrangler Boulder MT tires
Real Truck Swing Case
Katzkin leather
Go Rhino Dominator DS Sliders
Katzkin leather
What year is your truck? If it’s ‘14-19’ then an AEV Procal will work & it’s just a simple OBD II plug in. I had one for my ‘14 & it worked great…TPMS settings, speedo, tire diameter, gears, highs & fogs, seat belt chime.
If you have a 19+, the new trucks have a canbus security protocol protection to prevent cyber attacks via the OTA 4G antenna & the OBD. HD Rams has 60+ pages on this, start there. There’s two Can busses that require security by-pass. AEV makes a connector kit that bypasses one of the Can protocols, limiting the parameters you can change. The other requires a security bypass cable, a Bluetooth OBD II scanner, and a software program like Alpha OBD on a windows or Android OS.
Damn that sounds like some cyber military type security!! The truck is a 2024. Guess I will just drive with the tire pressure light on for a while.
Katzkin leather
Katzkin leather
OP , what Rusty says, but don’t forget the OBD II security by pass module for your 2024! Enjoy
