I’m in the market for some 2020 PW metal tail light guards, but none online state they’ll fit a PW.
Descriptions indicate it’ll fit a Ram 2500, but not a PW.
Anyone have any insight?
2020 PW rear tail light guards
Re: 2020 PW rear tail light guards
Anything that fits a 2500. Should fit the PW. The only thing different is parts of the frame and axles.
OP,,,,RUSTY X 2!
Post some picture/links to which ones you go with. Kind of thinking about getting some for mine (to hide the dent.)
