T-Case Position Sensor Replacement
ramv
Post by ramv » Fri May 10, 2024 4:31 pm
I got the "4wd shift in progress" message the other day. Fortunately, I have the BD 2wd low range so even if it tries it won't shift, just illuminate the LED on the switch. I bought a new sensor, Mopar part 6821 1454AA; but I can't figure out where the sensor is on the T-Case. I felt around but couldn't find it. The cats were a little hot so I didn't try from the passenger side, but I assumed it would be on the drivers side?
Any pictures or tips? Not urgent, I cycled into 4wd and back a few times and it seems fine again.
Re: T-Case Position Sensor Replacement
Post by RustyPW » Fri May 10, 2024 8:13 pm
The sensor is on the driver's side. Just above the transfer case shift linkage coming out of the case.
Damn forum won't let me copy and paste a picture. :angry:
ramv
Post by ramv » Sun May 12, 2024 2:16 pm
Thank-you!
