Is there a “permanent “ exhaust manifold/bolt fix. My 2013 has at least 2 broken studs and a cracked manifold on the right side.
I can’t find a good answer for a real fix.
I hear headers fix it and then hear most headers don’t fit.
I hear stainless bolts, but if they break you are really screwed.
Has anyone actually done something that worked long term.
Thanks Mark
Is there an exhaust fix
- SimonandSimonBeast
Re: Is there an exhaust fix
Did you ever get a solution to this? I have a '13 PW and at least 1bolt on the manifold is broken, giving me some pitter patter on cold start up. My shop says it is a good time to upgrade to headers if I wanted to fix it. I am also looking for headers and bolt improvements.
This is on my to do list for my 2012 also. The recommendation I have seen/heard the most is American Racing Long Tube Headers with some good fasteners.
I have been tempted to just try a set of JBA shorty headers but have heard mixed results.
Search Headers up at the top. There have been a number of discussions here about them over the years.
A warped manifold is what causes broken bolts, check the flatness with a straightedge, I've seen them out by as much as 1/4". The warpage causes extra strain on the end bolts until they pop. Don't just replace the broken bolt, have a machine shop surface it flat again and you'll get longer service life.
2008 Quad Cab - Stock RTI = 655, curb weight = 6081 lbs. Abel Components Plug & Play Locker Bypass®, Abel Components Sway Bar Bypass®, Abel Components Nanny Kill Switch®, Trailer Hitch Storage, MOLLE Door Panels, Wilton Hitch Vice, Locking Under Seat Storage Drawer, Smittybilt 2781 Air Compressor, 14K PullPal, Hi-Lift First Responder Jack, 25' Jumper Cable System, Slip Yoke Eliminator in a Can, Evolution vs. God, Share the Umbrella, Make sure you're right with God before you meet him!
Long tube headers from ARH is what I did with my 6.4. Didn't break the manifold bolts, though I don't think its as prevalent a problem with the 6.4 as it is the 5.7.
The headers will resolve the broken bolt issue, but it does come at the cost of more noise under the truck. The stock manifolds keep the engine very quiet unless you have a leak, but with headers it almost sounds like you always have a leak, because the thinner material doesn't dampen valve noise and exhaust pulses as well...also its a bit harder to keep them sealed up depending on what you get. My ARH headers with a ball and socket collector seem to seal fine at that point, but the slip fittings tend to leak a little bit until hot or you way over tighten the clamps.
Overall, headers are worth it for the performance gains alone. The stock manifolds really screw up the great flow characteristics these Hemi's heads have.
Make sure it's flat?
I snapped a few before the shop put a straight edge on it... turns out the headers were warped.
Had those decked at the machine shop, and haven't snapped one since.
This is on my '05.
This is on my '05.
Stage8 has a locking fastener kit for the exhaust manifolds that is really well engineered and made.
https://www.stage8.com/product/8916-dod ... -bolt-kit/
Never tried it with a stock manifold, but fantastic with headers
Do you know if this is a bolt up option for the '13 5.7, without and other modification to the exhaust system? And wrap or not wrap them? This is an area of concern I have little experience with, so any help is appreciated.
