Windshield Wipers malfunction - need help!
doc91w
Post by doc91w » Sat Feb 16, 2013 11:50 am
So i know that the wipers on my 05 are practically possessed. For years whenever i used the intermittent wipe setting the wipers danced to their own tune, a single wipe slow, a double wipe fast, whatever it wanted to do. I never complained because at least they worked ( much better than my lockers )! So two days ago on my way to work i hit the wipers to knock off a little snow. The wipers popped up an inch and stopped. I checked for icing up and all the usual stuff and while i watched they popped up another inch. I wiped the windshield with a towel. 25 minutes into my commute the wipers kicked up right into my line of sight, and five minutes later they started functioning normally. I used the switch in all the settings and it was as it should be. Yesterday i needed the wipers right away for frost and got nothing. About a minute later they popped up an inch. I couldn't drive so I stole my wifes car for work. Today i checked the relay and swapped it out with another one. Didnt fix it - still no wipers. Any ideas for a self - help fix or am i doomed to return to the stealership?
pdavey
Re: Windshield Wipers malfunction - need help!
Post by pdavey » Sat Feb 16, 2013 3:28 pm
It is probably the contacts in the steering wheel. From what I have seen there are no wires that go directly to the switch, instead they terminate in a contact plate that the switch connects to in the steering wheel. If it isn't the relay or the motor than like the switch isn't making good contact with the contact plate. What I have found that works sometimes if you have the tilt steering. Turn on the wipers and than unlock the tilt and push the steering wheel up and down while it is on. I have done the same thing with my blinkers and it has cleaned the contact plate by doing that.
Worth a try. Either that or add more blinker fluid :grin:
Sent from my DROID DNA
Performance Mods:
Other Mods:
Suspension/Protection Mods:
Style/Other Mods:
Quasimoto
Post by Quasimoto » Sat Feb 16, 2013 3:44 pm
In my 2005, I had to have the Wiper Control Module replaced when they stopped working at about 50,000 miles.
2005 Dodge 2500HD 4x4 Quad Cab
5.7 Hemi, Auto trans
Lockers and 4.56 Gears
5" lift springs on front, 3" Blocks and Air Bags w/ 3" spacers on rear
38x15.5R18 Toyo Open Country Mt Tires, 18x12 Fuel Hostage wheels
Bushwacker Extend-A-Flares, Westin Sportsman one piece grille guard
Kargo Master Canopy rack, Front receiver hitch
11,000 lbs Portable Winch
Led lighting (360 degrees)
Big Steel - Sport Canopy, DAC truck tent, 8x10 Tarp Awning
CB radio, UHF 2-way radio, Garmin Rhino GPS / GMRS handheld radio and 3w Cell booster
205L (55gal) Aux Fuel Tank
Bed in canopy w/ storage drawer
AFE Cold Air Intake w/ 4" Exhaust
doc91w
Post by doc91w » Sat Feb 16, 2013 6:26 pm
Ill go and try the steering wheel trick and cross my fingers. Im not really anxious to start pricing out control modules and labor costs.... I
vanished
Post by vanished » Sat Feb 16, 2013 9:23 pm
My 05 also had the wiper park position sensor go bad. Part of wiper assy
ramit99
Post by ramit99 » Sun Feb 17, 2013 8:00 am
On my 06 the signals started acting weird. Went to dealer and there was a TSB for the signal lever which also controls your wipers. They replaced it for free.
doc91w
Post by doc91w » Sun Feb 17, 2013 10:48 pm
Good to know. I tried moving the steering wheel up and down with the wiper switch in the on position and still its broke. Guess i need to check into the TSB. Do you know if it covered 05's too? It'd sure be nice to NOT get ripped of by the stealership just once!
doc91w
Post by doc91w » Sun Feb 17, 2013 10:51 pm
Hey just wondering how many of you have a flickering bright lights indicator light? When my dims are on there is a faint flickering of my bright lights indicator light. I wonder if this is all connected?
Quasimoto
Post by Quasimoto » Mon Feb 18, 2013 1:43 pm
The Dealership payed for the replacement of my Module. But that was about 4yrs ago. I know it wasn't Warranty because that was run out, so it must have been a recall or bulletin.
Quasimoto
Post by Quasimoto » Mon Feb 18, 2013 1:50 pm
doc91w wrote:Hey just wondering how many of you have a flickering bright lights indicator light? When my dims are on there is a faint flickering of my bright lights indicator light. I wonder if this is all connected?
Mine does the same thing, but it is very faint so I can't see it if I look straight at it but if I look to the side of the guages I can see it in my periferal (something about the side of my retina being more sensitive to light).
I always wondered why it flickered like that, but everything else works fine.
LKelly
Post by LKelly » Mon Feb 18, 2013 11:54 pm
I think I've got the same issue - I can barely see a light flickering as I'm driving, but when I try to see which one it is I can't tell.
I've also got the wiper issue...instead of intermittent, the wiping seems to be pretty much randomly spaced and sometimes it'll wipe two times in a row. I've also occasionally had the wipers come on and make just one swipe when the switch is turned off, though that's only happened a few times.
I've been ignoring the issue, but after your post I might have to look into it...I can't really afford to have them stop working completely. I always assumed that mine were acting up because I'd hit them on a lot of tree branches when off-roading, and I know that the linkage is a bit messed up. Plus, my horses have chewed on the passenger's-side wiper a few times, and they weren't very gentle...for some reason horses find wiper blades really fascinating (and tasty). I might have to give the whole steering-column tilting thing a try, to see if that helps.
Post by FirerescuePW » Tue Feb 19, 2013 12:38 am
Now that's something I didn't expect to hear even a little bit.
RedMan
Post by RedMan » Tue Feb 19, 2013 6:09 am
There is a bulletin out there for the 05 PW wipers malfunctioning. I had mine replaced about 5 years ago.
I still have some issues with my wipers, granted it has not happened in almost a year now. When I hit my remote unlock, the wiper blades would come on for one swipe. I always looked at it as she does what I do when I first wake up, rub my eyes :doh: .
Our trucks have a mind of their own, which is why I find myself talking to her alot. She needs to know that she is loved, JUST like a woman :mrgreen:
Power Wagon Registry #47
- Thuren steering upgrade
"The" Wifes Car
"Faith" 2014 Charger RT Max
My Toy
"VISCO" 2013 196CC Tidewater
doc91w
Post by doc91w » Wed Feb 20, 2013 9:11 pm
I've been looking for the TSB or recall that includes the 2005 Power Wagon or Ram 2500 and am having a really tough time finding it. Do any of you happen to have the TSB or Recall number hidden away somewhwer? My local stealership (not many options around here) says they can't find anything regarding my truck to cover the cost of repair :box: (likely story)... anyway I'll keep searching online. Any help would be appreciated.
GunniPWguy
Post by GunniPWguy » Wed Feb 20, 2013 9:23 pm
RedMan wrote:There is a bulletin out there for the 05 PW wipers malfunctioning. I had mine replaced about 5 years ago.
I too enjoy a truck with A MIND ALL HER OWN. Intermittent wiper action. serv 4wd light when the son plays with the switches, etc. :doh: Just the other day I went to wash my wifes subie and came back home to see my truck in the drive and told my wife "I had better go wash Christine too so she doesn't get mad" My wife just shook her head and said "OK honey...Do what you gotta do".. :)
