Hi lift jack ideas
Re: Hi lift jack ideas
Post by olyelr » Sat Mar 17, 2018 12:26 am
Nice thanks for the pics!
Easttnrhino
Post by Easttnrhino » Sat Mar 17, 2018 8:50 pm
I like, good idea. Thanks
Enjoying beautiful east TN
Post by adeluca73 » Sun Mar 18, 2018 11:52 pm
Low_Sky wrote:
Fri Mar 16, 2018 9:32 pm
I know this thread is old, but here's how I just mounted mine in a RamBox truck. Took the jack apart to its major pieces: jack bar, foot (replaced the bolt with a 1/4" pin), handle (replaced the cotter pin with a single leg snap button), and running gear. I built plywood dividers and a jig to hold the jack bar and handle. The handle's held on with Quick Fist clamps, and the jack bar is on 1/2" bolts with wing nuts.
That’s a slick way to shoehorn that monster in there!!!
    - Strip LEDs
  • Garmin Power Switch Powering:
Post by Reloaderguy » Mon Mar 19, 2018 12:14 am
My wife said the same thing this morning.
Post by adeluca73 » Mon Mar 19, 2018 8:17 am
Figured it was you would chime in....I couldn't have teed it up any better aside from subtitling "that's what she said" after. Nice to see we conform to expectations....
    - Strip LEDs
HOBBES
Post by HOBBES » Mon Sep 21, 2020 5:14 pm
2015 Jeep Wrangler JKU Rubicon Hard Rock
2006 Dodge Ram Power Wagon
2004 Yamaha FJR1300A
JRHPWRWAGON06
Post by JRHPWRWAGON06 » Sat Sep 26, 2020 7:11 pm
Those things weigh a ton. I would keep it in the garage unless i was Wheeling. Save on gas.
OPTIONS-
MODS-
Post by Bill2014 » Mon Sep 28, 2020 2:55 pm
You will only need it if it is in your garage :poke:
Post by KevinABQ » Mon Sep 28, 2020 11:01 pm
Nobody ever forgets their recovery gear on a shelf in their garage. Particularly if it stays in the truck.
Mule
Post by Mule » Mon Sep 28, 2020 11:37 pm
A good checklist and pre-trip inspection goes a long ways!
(Going through a checklist for the moto for a ride tomorrow... helmet, gloves, boots, radio(s), camelbak, FAK... batteries charged? Oil change good? Bike fuel'd? Coolant check'd?
I forget a lot of things, but I don't "forget things" with a checklist+pretrip! 8-) )
btsbarton
Model Year: 2019
Post by btsbarton » Sun Oct 11, 2020 9:16 pm
You’re aware how much these things already weigh right? lol what is an extra 50 pounds
Oilbrnr
Post by Oilbrnr » Wed Oct 14, 2020 11:33 am
What are you using as lift-points on the PW and what do you expect to achieve with that Hi_lift?
:popcorn:
'16 with '17 FWC
EasyDoesIt
Post by EasyDoesIt » Wed Oct 14, 2020 12:49 pm
:popcorn:
In a pinch you can use the front tow hooks. I've done it, I wouldn't get under the truck but to change a tire or get the tire out of a hole, id do it again.
Also the rear hitch would work.
Or get one of those wheel straps.
Post by Retired BLM Rig » Sat Oct 17, 2020 9:46 am
I carry a Hi Lift for the same reason I carry a fire extinguisher and a first aid kit. The Boy Scout motto is "Be Prepared".
phpBB [video]
Clickable link for Tapatalk
HOBBES
Post by HOBBES » Tue Oct 20, 2020 7:38 pm
:popcorn:
I wish I had a set of MOPAR factory rock rails installed to lift from. Instead, I have the lift-mate wheel strap, bumper lift, off road base, winch kit, etc. I like the idea of it being capable of being used as a spreader. The Jackmate allows me to pry open a car door like a can opener, if necessary.
btsbarton
Model Year: 2019
Post by btsbarton » Sat Oct 24, 2020 1:29 pm
:popcorn:
If you have rock sliders, they are good lift points for a HiLift.
If you get the “Lift Mate” wheel lift kit, it’s great for lifting one corner to place a traction board or rocks to fill a hole you’re stuck in, even without rock Sliders. Same concept if you need to break suction of a stuck vehicle framed out in mud/ice.
You can use the instability of the jack to its advantage to “cast off”...jacking it up and pushing or driving off the jack to reposition a vehicle. This isn’t for beginners/faint of heard though, as it can be dangerous if done wrong.
Hilift can also be used to press bearings, break tire beads, and It can be used as a winch in a pinch (slow, not much travel before having to reset)
I think the bigest misconception is HiLifts are for changing tires on lifted vehicles.... they are not! They CAN be as a last resort, but the MUCH SAFER route is to use the (stock) bottle jack under the axle and a 4x4 block of wood to gain the extra height if needed.
