AAM ball joints.
AAM ball joints.
Are these OE for our trucks? Any feedback on them would be appreciated.
2005 Bright Silver PW
2005 Mineral Grey PW
Re: AAM ball joints.
I installed the Carli ball joints about 60,000 miles ago. And they are still tight.
I have Dynatrac ball joints in my truck. After about 140k miles I rebuilt them, tops were still tight bottoms were loose. For about $195 you can get the rebuild kit for all four ball joints and do the work without having to remove them from the axle, very pleased with this product.
- Oilbrnr
Where do EMF balljoints fall on the good, better, best rating of possible replacements?
'16 with '17 FWC
Unknown.
Out of stock everywhere. May have to goo Moog.
If they are splined. Stay away from them.
Tried all weekend to get the hubs off with no luck. Took it to a local shop and it took them 3 days to get the hubs off. Them suckers were on there. Also put 2 new skf hubs on.
When I replaced my ball joints. I had to use a 7" fiber cut off wheel and cut the studs on the ball joints because I couldn't remove the unit bearings. Once I got the steering knuckle out and on the ground. i used a sledge hammer to knock the unit bearings out.
Are these factory ball joints?? $69 per side seems pretty cheap!ACL123 wrote: ↑Thu Oct 08, 2020 7:32 pmWent with the AAM
https://www.dennysdriveshaft.com/p3269_ ... _2500.html
2010 PW, 295/70-17 Mastercraft Courser MXT, Borla Exhaust, K&N CAI, Ported Throttle Body, Everything Else all factory
Not sure if our trucks come with these but its the same company who makes our axles.jj141979 wrote: ↑Fri Oct 09, 2020 9:53 amAre these factory ball joints?? $69 per side seems pretty cheap!ACL123 wrote: ↑Thu Oct 08, 2020 7:32 pmWent with the AAM
Why would you replace junk with the same junk?jj141979 wrote: ↑Fri Oct 09, 2020 9:53 amAre these factory ball joints?? $69 per side seems pretty cheap!ACL123 wrote: ↑Thu Oct 08, 2020 7:32 pmWent with the AAM
