fuel sensor
w2dodge
fuel sensor
Post by w2dodge » Sun Jul 19, 2020 10:39 pm
Any one tackle a faulty sending unit?...Fuel gauge in the cluster works fine when tested...(hold down mileage reset..while turning on an off 3 times with ignition key)..I'm hoping I dont have to drop the gas tank...
cb1987
Re: fuel sensor
Post by cb1987 » Tue Jul 21, 2020 11:57 am
if its about the same procedure as a dakota then lifting the bed may be far easier. i did a dokata myself by lifting bed about 8in off the frame rails. was fairly easy job actually.
Mule
Re: fuel sensor
Post by Mule » Tue Jul 21, 2020 1:17 pm
Yup. My usual shop unbolts the bed and slides it over a bit to get to the pump.
Other shops will drop the fuel tank out of the truck to replace the truck.
Shitty shops will wreck the fuel tank in the process. :angry:
w2dodge
Re: fuel sensor
Post by w2dodge » Tue Jul 21, 2020 8:04 pm
yep I figured that....pump works ..and i have less than a half tank.. most likely doing this alone...just might waste the gas idling every day ...and drop the tank
jj141979
Re: fuel sensor
Post by jj141979 » Thu Jul 23, 2020 9:22 am
Slide the bed back... 6 bolts... need at least 3 strong dudes or chicks... pump is right behind the cab... took me about 1.5hrs to do fairly easy
2010 PW, 295/70-17 Mastercraft Courser MXT, Borla Exhaust, K&N CAI, Ported Throttle Body, Everything Else all factory
Re: fuel sensor
Post by Colibri » Mon Jul 27, 2020 12:57 am
Absolutely move the bed rather than drop the tank
w2dodge
Re: fuel sensor
Post by w2dodge » Fri Aug 21, 2020 6:53 pm
getting there
w2dodge
Re: fuel sensor
Post by w2dodge » Sat Aug 22, 2020 11:26 am
heres some progress
w2dodge
Re: fuel sensor
Post by w2dodge » Sat Aug 22, 2020 6:57 pm
all done... 1 of many things I gotta do...had shoulder surgery and a total hip replacement in the past year and half.. .
Re: fuel sensor
Post by RustyPW » Sat Aug 22, 2020 9:44 pm
Did it fix the problem?
w2dodge
Re: fuel sensor
Post by w2dodge » Sun Aug 23, 2020 2:37 pm
yes it did....thank god
