Sway bar disconnects in 2wd but not 4wd
Socalpw
Post by Socalpw » Thu Apr 09, 2020 3:57 pm
I have a 2005 power wagon the sway bar will only disconnect in 2 wheel drive. The only thing I have changed is I hard wired my lockers to separate switches. After I hardwired them the sway bar worked like it should and would only disconnect in 4hi or 4lo. Has anyone else had the same issue? :angry:
