Can using the ProCal prevent Uconnect update?
I've never had any problem with my Uconnect updating on my 2015 until I adjusted my speedo with the ProCal. Now I keep getting the update request and I tell it OK, but then I eventually get the message that it failed and to go visit the dealer.
- Rodeoflyer
Re: Can using the ProCal prevent Uconnect update?
I have the procal and mine updated successfully.
Same, mines a 2018.Rodeoflyer wrote: ↑Sun Nov 03, 2019 12:54 pmI have the procal and mine updated successfully.
You might try disconnecting your battery for an hour to try and reset the system. I'd try that or maybe pulling and replacing the applicable fuses before going to the dealer.
Good luck,
Steve
Ok I just wanted to check. Didn't know if the procal changed some value that didn't match when the uconnect was verifying it's update or something.
I highly doubt it
Which also makes me wonder if I end up taking it to the dealer, should I "undo" the procal and return the speedo setting back to factory while they are working on it.
It finally took via USB after disconnect the battery for a while.
