Why is My Front Axle Leaking?
Nailhead
Post by Nailhead » Sat Jan 26, 2013 11:31 am
I've got gear oil leaking out both sides of my front axle, and I'm looking for some idea of why.
The axle shafts have no side-to-side play, and the breather isn't plugged. The fluid is Royal Purple and is in perfect condition: no water or any other obvious contaminants.
Is this a typical side effect of installing lockout hubs, then?
The dealer wants $950-ish for the repair, and a local shop wants $350, so I want to avoid a repetition of this problem.
Thanks.
'08 Flame Red Quadcab with Spyntec & Teraflex hubs, Mag Hytec pan & covers, Carr rock rail steps, Warn wireless winch controller, Hawk Performance brake pads, Ranch Hand crossover box, and Turbolined bed.
pdavey
Re: Why is My Front Axle Leaking?
Post by pdavey » Sat Jan 26, 2013 12:54 pm
Sounds like the seals have gone bad. I had a string of front axle seal issues under warranty when I first bought the truck. There was no real reason. Then I got them done at merchants and havent had the issue since. Wondering if it was the aftermarket axle seals that did it.
Sent from my DROID DNA
Performance Mods:
Other Mods:
Suspension/Protection Mods:
Style/Other Mods:
Post by FirerescuePW » Sat Jan 26, 2013 6:51 pm
Did you just recently install the lockout hubs? Sounds like the seals were damaged on reassembly.
Post by TwinStick » Sat Jan 26, 2013 8:53 pm
FirerescuePW wrote:Did you just recently install the lockout hubs? Sounds like the seals were damaged on reassembly.
This ^^^.
http://www.quad4x4.com/cgi-bin/commerce ... n&key=4685
http://www.quad4x4.com/cgi-bin/commerce ... &key=10945
Nailhead
Post by Nailhead » Sun Jan 27, 2013 9:35 am
I installed those 2 1/2 years ago. That's part of the reason I'm mystified as to why this just happened. On BOTH sides.
It makes me think the diff carrier bearings are going south.
Nailhead
Post by Nailhead » Sun Jan 27, 2013 9:38 am
pdavey wrote: Wondering if it was the aftermarket axle seals that did it.
There are no aftermarket seals around here-- dealer-only item. :roll:
VA_Wagon Man
Post by VA_Wagon Man » Sun Jan 27, 2013 11:27 am
I had both of my inner Axel seals replaced at a dodge dealership fir $400 and some change......i had a nice special favor done for me. Its normally a $1000+ job.:shock:
I had the left side start leaking after a significant deer hit to the front left tire. They replaced both for the $400....
Long Gone:
Rausch Creek 2010 Fall Run
Rausch Creek 2011 Spring Run
Rausch Creek 2011 Fall Run
Rausch Creek 2012 Spring Run
Post by RustyPW » Mon Jan 28, 2013 12:30 am
When replacing the axle shafts back in the housing. You have to be careful of the axle seals. They nick real easy. In your case, 2 1/2 years. How many miles?
Nailhead
Post by Nailhead » Mon Jan 28, 2013 9:40 am
RustyPW wrote:When replacing the axle shafts back in the housing. You have to be careful of the axle seals. They nick real easy. In your case, 2 1/2 years. How many miles?
30K +-
To my way of thinking, 2 1/2 years & 30,000 miles takes the lockout installation off the list off probable causes for this sudden hemorrhage. If those seals had been compromised during that install, it seems to me they would have started leaking right away or not at all. I could be wrong, but it doesn't seem logical that all of the sudden they would just start leaking due to damage incurred so long ago.
IIRC, we reinstalled the axle shafts very gingerly with these seals and their preservation in mind.
Nailhead
Post by Nailhead » Mon Jan 28, 2013 9:42 am
VA_Wagon Man wrote:i had a nice special favor done for me.
Yes, you did. :rockon:
Post by TwinStick » Mon Jan 28, 2013 10:07 am
Maybe the rubber just dry rotted & cracked ???
verdesardog
Post by verdesardog » Mon Jan 28, 2013 10:24 am
I took my axles out to replace ball joints several months ago, my seals aren't leaking...yet. you must have dammaged them slightly.
Nailhead
Post by Nailhead » Thu Jan 31, 2013 1:12 pm
Fix'd.
$371 was all it cost.
Hope it lasts.
Thanks for all the input.
pdavey
Post by pdavey » Thu Jan 31, 2013 2:18 pm
Glad to hear. What was the fix?
Performance Mods:
Other Mods:
Style/Other Mods:
VA_Wagon Man
Post by VA_Wagon Man » Thu Jan 31, 2013 9:42 pm
Nailhead wrote:Fix'd.
Hope it lasts.
That's great! I'm with Peter, what was involved?
Long Gone:
Nailhead
Post by Nailhead » Sun Jul 07, 2013 3:37 pm
Been away a while...
I actually don't know how they fixed it, but I'm almost certain they didn't remove the diff.
Still working great, though.
