Post
by RustyPW » Sat Nov 03, 2018 1:28 am
Well, I had to take my PW to the dealership for work.
While at the OBX a couple weeks ago. My A/C started to blow hot air. I was thinking of the problem Ducky had with this. Start up and it would blow cold air, then hot, then cold again. Same problem as Ducky. So I took it in. They check the system. Hardly any freon in it. They recharged it and put a dye in it too. This is the first time the system has been looked at since I bought the PW over 10 years ago. While I was picking the PW up. I asked about replacing the broken exhaust studs, and would that be covered under my Life Time Powertrain Warranty. They looked it up and said yes.
So I took the PW back in Wednesday evening. They worked on the PW Thursday and finished it up. Picked the PW up this morning. No charge for replacing all of the studs on the right side of the motor.
My motor is quite again. Plus they checked the A/C sytem for leaks. No leaks found.
The only time my PW has seen a dealership service bay was to do recalls and to change the clock spring under the steering wheel.
My build thread.
http://forum.powerwagonregistry.org/vie ... =13&t=2826
