New Carli Stablizer Sneak Peak!
Posted: Mon Jul 30, 2012 5:07 pm
by Skyd Ram
Another awesome product sneak peak from the wizards at Carli Suspension!
Fresh from the lab!
This is a prototype stabilizer shock that Sage has been working. It uses a stainless steel body, anodized aluminum mounts with FK rod ends and a nitride hardened steel shaft. This will be a Carli exclusive part that offers the ultimate in corrosion resistance. This new part will have to see some extensive testing before Carli will stamp it done.
Pricing won't be much more that the Bilstein based clear powdercoated stabilizers that are already offered. We'll keep you posted as to when these will be available although it won't be very soon.
Re: New Carli Stablizer Sneak Peak!
Posted: Mon Jul 30, 2012 8:08 pm
by 2012 PW ST
Very cool. Thanks for the preview George. Sounds like it will be durable.
Definitely a good idea...especially for those of us with stabilizers that will see all kinds of winter salt, lava rock and grime.
Posted: Fri Aug 17, 2012 12:50 am
by Skyd Ram
2012 PW ST wrote:Very cool. Thanks for the preview George. Sounds like it will be durable.
Yeah,
This is a good starting point for a possible future for a stainless shock line up. But like all things Carli it will have to be tested and proven before any steps are taken towards production.
Posted: Sat Aug 18, 2012 12:47 am
by TwinStick
They would corner the market in my neck of the woods. The rust belt people would sure like a nice shinny SS shock, to look & perform like new for more than 1 year.
Posted: Thu Sep 06, 2012 9:31 am
by MSparks909
Looks awesome. When my factory stabilizer goes out I'll be upgrading to this
Posted: Tue Sep 11, 2012 12:09 pm
by Skyd Ram
They've got a few in testing right now. One is on a truck that spends a lot of time on the beach. The other was tied to rope and tossed into the ocean an tied to the pier. So far the stainless body and the shaft are holding up great. Obviously the bearings on the ends are showing some signs of corrosion but that is generally combated with a little squirt of WD40 from time to time.
Posted: Tue Sep 11, 2012 10:19 pm
by TwinStick
Skyd Ram - Here is a question: Is there any way that they could make a SSteel bolt type deal with the taper, so this could be used on trucks like mine with the old Y style steering ? I am really digging these but they prob wont work on my truck.
Posted: Tue Sep 11, 2012 11:39 pm
by Skyd Ram
TwinStick wrote:Skyd Ram - Here is a question: Is there any way that they could make a SSteel bolt type deal with the taper, so this could be used on trucks like mine with the old Y style steering ? I am really digging these but they prob wont work on my truck.
Unfortunately even with the correct mounting adaptors, the attachment points on the older steering setup is a bit too short for a stabilizer like this as well as the Bilstein 7100 that they currently use.
Posted: Thu Sep 13, 2012 10:26 pm
by TwinStick
Knowing this, the factory replacement part will probably be $500 !!!
Posted: Fri Sep 14, 2012 10:18 pm
by RustyPW
About $160. That's what I paid for mine when I did the 'T' linkage up grade.
Posted: Sat Sep 15, 2012 7:15 am
by AceMan
Skyd Ram wrote:They've got a few in testing right now. One is on a truck that spends a lot of time on the beach. The other was tied to rope and tossed into the ocean an tied to the pier. So far the stainless body and the shaft are holding up great. Obviously the bearings on the ends are showing some signs of corrosion but that is generally combated with a little squirt of WD40 from time to time.
So does that mean we should be spraying WD40 on our current Carli bearings?
Posted: Sun Sep 16, 2012 11:08 am
by TwinStick
Nope, Fluid Film !!! LOL
Posted: Sun Sep 16, 2012 1:13 pm
by AceMan
LOL! Can we use that on the exposed tie rod and draglink threads?
Posted: Tue Sep 18, 2012 3:21 pm
by Skyd Ram
If you live anywhere that uses salt on the roads in the winter or you live near the ocean I would spray everything made out of metal with Fluid Film, WD40, Etc.........
Posted: Thu Sep 20, 2012 11:40 pm
by TwinStick
Yes you can. It is Lanolin based. You guys REALLY need to read up on that shit. Good stuff. Won't harm rubber or plastic or o-rings
http://www.fluid-film.com/
http://www.theruststore.com/Fluid-Film- ... 4AodmQ0Apw
Posted: Fri Sep 21, 2012 12:49 am
by AceMan
Thanks, gentlemen. With all the salt we get in MI, NY, PA, and the rest of the northern states and Canada, we need a 5 gallon bucket of that stuff.
I'm ordering 2 spray cans.
Posted: Fri Sep 21, 2012 8:41 pm
by TwinStick
They go quick. You should order a case.
Posted: Thu May 08, 2014 11:53 pm
by Skyd Ram
***UPDATE***
Carli now has this stabilizer available for the trucks with the older Y-style steering. It runs $299 and comes with a new anodized billet clamp and hardware. We are running one on Tommy's (employee) '08 Hemi 2500 with great success!
http://www.8lugtruckgear.com/Dodge-Susp ... -p836.html
George
