2012 with bds long arm lift just finished 01/07/13
Re: 2012 with bds long arm lift just finished 01/07/13
Post by 2wagons1driveway » Wed Jun 04, 2014 3:08 pm
Ahha! Regulator, gauge, and 10' line. Should work well to put some nitro in them shocks!
Post by TwinStick » Wed Jun 04, 2014 11:48 pm
:rockon:
Post by 2wagons1driveway » Sat Jun 07, 2014 10:00 pm
Fronts are in. Need bigger coils now. With the shock extended (no limit straps) my coils are falling out lol have to save some more dough for Carli coils next maybe. Need to find a way to chop my fender liner though so the acv's co-exist with the fender liner cause their facking massive resi's !!!!
Changed the plugs today also...wow what a pain in my backside. Doesn't help the trucks pretty big. Glad I have that bumper to stand on now!
Post by 2wagons1driveway » Sun Jun 08, 2014 12:49 am
Rotfl ya that would Deffinately help!!
Post by 2wagons1driveway » Sun Jun 08, 2014 10:26 pm
ImageUploadedByTapatalk1402280511.500551.jpg[/ attachment] Rears are in front fender liners are cut. Now waiting for coils and brake lines! Apperantly when you build a long travel suspension you need to extend your brake lines lol so ya! need them. Driveshaft is still being lengthened pipe was back ordered. Thuren coils have been ordered hoping strapt will have them soon and send them up here so I can pay an extraordinary amount of duty on them lmao :( [attachment=0]ImageUploadedByTapatalk1402280760.583920.jpg
Post by TwinStick » Sun Jun 08, 2014 11:41 pm
:rockon: Looks awesome !
You gonna coat the shiny aluminum with anything to prevent corrosion ?
Stickman
Post by Stickman » Mon Jun 09, 2014 12:47 am
Damn those look sexy. The whole thing looks sexy. That last pic of the front with it on the ground looks badass, those rims look good. Did they increase the ride height any? Or is that just with a full charge in them? Looks like it's sitting a little higher, or maybe that's just me. :excited: You're making me want to do all of this to mine and make it look like it's twin. :cash:
Post by 2wagons1driveway » Mon Jun 09, 2014 9:53 am
TwinStick wrote::rockon: Looks awesome !
I'm heating from skydram that I don't really have to he says the triple plate bilstein coating works well aha isn't corrosion he showed me a pic of his Truck which lives in michigan after 3 years their still shining!
Post by 2wagons1driveway » Mon Jun 09, 2014 9:56 am
Stickman wrote:Damn those look sexy. The whole thing looks sexy. That last pic of the front with it on the ground looks badass, those rims look good. Did they increase the ride height any? Or is that just with a full charge in them? Looks like it's sitting a little higher, or maybe that's just me. :excited: You're making me want to do all of this to mine and make it look like it's twin. :cash:
I think they did alittle bit ! Only have 90psi of air pressure in them now just to drive it around the shop and my front yard until new Thuren coils come and brake lines so I can actually use this insane amount of travel without my coils saying good bye and taking the brake lines with them! Also have to chop my exhaust and lower it so the driveshaft can actually articulate to the full width of the Tavel now too!
Post by 2wagons1driveway » Mon Jun 09, 2014 9:37 pm
Shackles are here! Does anyone know if I have to grease them or if their pre greased? (That's you 05!!) Don't want to damage the bushing by over greasing! Also a pic of finished ride height before Thuren coils and shackles get here Deffinately looks a bit taller in the front could be the slope of my shop driveway though to! Hoping the coils won't give me a vibration cause they will probably raise the front another 1/2" over what it is now I figure and I don't have a t case turn
Post by 2wagons1driveway » Mon Jun 09, 2014 9:38 pm
Ps I think the bilsteins are a steal resi! :p
Post by 05PWrockcrawler » Tue Jun 10, 2014 12:56 am
Very nice. I greased the bolt before I installed it (makes for an easier install and quieter, but not cleaner lol) then greased them once mounted. Made them move easier. Enjoy!
slimstick
Post by slimstick » Tue Jun 10, 2014 9:55 am
Truck looks awesome. I have the 2010, same color. I'm ordering the BDS lift today and have a quick question for you. I haven't seen an aftermarket steering stabilizer in your photos. Did I miss it or was there no issue with the lift and tires affecting the driving/handling of the truck? I don't want to purchase one at the moment if it's not necessary and the drivability is unaffected. Also, what did you use for spray/paint your grill and body? Was it LineX or just bedliner in a can that you can buy at your local store. Thanks.
Mr.Smith
Post by Mr.Smith » Tue Jun 10, 2014 12:41 pm
05PWrockcrawler wrote:Very nice. I greased the bolt before I installed it (makes for an easier install and quieter, but not cleaner lol) then greased them once mounted. Made them move easier. Enjoy!
X2...this is what I also did for installation.
Post by 2wagons1driveway » Wed Jun 11, 2014 7:35 pm
slimstick wrote:Truck looks awesome. I have the 2010, same color. I'm ordering the BDS lift today and have a quick question for you. I haven't seen an aftermarket steering stabilizer in your photos. Did I miss it or was there no issue with the lift and tires affecting the driving/handling of the truck? I don't want to purchase one at the moment if it's not necessary and the drivability is unaffected. Also, what did you use for spray/paint your grill and body? Was it LineX or just bedliner in a can that you can buy at your local store. Thanks.
Got a Carli low mount!! Drive ability was fine with stock one but I heard the Carli one is better so I tried it and I've been liking it so far!! If you could afford line x I would go with them! But ya I used duplicolor bed armour for the side of the truck and for the grill I used another smoother bed liner. And then a flat black plastic acrylic over top to give it the same color as the flares which are also done in bed liner
Post by 2wagons1driveway » Wed Jun 11, 2014 7:36 pm
Okay so they can get a few pumps of grease after being installed! And grease the centre section of the bolt also??
slimstick
Post by slimstick » Thu Jun 12, 2014 8:55 am
Thanks for the reply. Yeah, found a local LineX shop that will do the grill for a $100 and the bumpers for $150 each if I remove and bring them in so will more than likely go that route. Noticed you left your rear bumper in chrome...I'm considering doing the same since I have chrome exhaust tips but would really like the truck to match up all the way around so might consider shortening the tips/exhaust to further under the truck.
Post by 05PWrockcrawler » Thu Jun 12, 2014 10:03 am
That's correct sir. Been working good like that for me and I actually took it apart 2 days later to change holes and it was very easy. Another tip to adjust it is a small bottle jack between the rear spring and body and just jack up until hole lines up and insert bolt instead of fighting it. Good luck.
Post by 2wagons1driveway » Thu Jun 12, 2014 10:04 am
Mr.Smith wrote: X2...this is what I also did for installation.
Sweet! Sounds good thanks 05.
Post by 2wagons1driveway » Thu Jun 12, 2014 10:06 am
I wanted to do the rear also but I think I'm just going to wait it looks like way more of a pain then the front to remove and I'll probably have it replaced with a custom fab'd one that has room for a fairlead and still leaves good space between the d ring mounts and the pdc's cause I know the d ring mounts set the pdc's off all the time on the smittybilt rear bumpers which would be annoying and pointless to keep them
Post by 2wagons1driveway » Sat Jun 14, 2014 3:15 pm
I haven't put any nitro in these shocks just shop air pressure I'm very impressed already their eating speed bumps I agree with everyone's said about Carli feels firm but the faster you hit something the smoother it is!!
Post by 2wagons1driveway » Fri Jun 20, 2014 8:49 am
Nitro tank-bit the bullet and just bought one yesterday.
Welded in the limit straps too waiting on Thuren coils which will be here today! :)!
Also installed my lengthened driveshaft and greased the hidden zerk! Marked it with some paint to help find it. Damn it felt good taking that spacer out!!
That's right I painted it red!! Lol it's what I had in stock....matches the shackles lol
also cut and lowered the exhaust for the extended travel shocks and lower driveshaft angle now. Found some sweet exhaust clamps in my tool box from
When I worked at Audi that's fit the hemi exhaust perfect literally chopped twice with a sawzall installed these couplings and lowered it approx 3/4" -1" nice and tight no leaks way cheaper then getting a new exhaust too!!
waiting on ss brake lines now and new carli diff cover to complete the front end then move to the back install shackles remove overload leafs etc! Then mod the skid plates again.
Post by 2wagons1driveway » Fri Jun 20, 2014 11:03 am
Post by 2wagons1driveway » Fri Jun 20, 2014 11:04 am
So if anyone's doing a lengthened driveshaft or exhaust id suggest just getting your hands on a pair of those clamps makes life super easy and much cheaper then buying a replacement exhaust or piece to install.
