Glad to be here, now let's make this truck a beast.
Mr.Smith
Re: Glad to be here, now let's make this truck a beast.
Post by Mr.Smith » Fri Apr 08, 2016 8:57 pm
Has anyone looked into building out our stockers into a true bead-lock setup?
Post by 2wagons1driveway » Sun Apr 10, 2016 9:53 am
Mr.Smith wrote:Has anyone looked into building out our stockers into a true bead-lock setup?
I've seen a few guys have trail ready wheels have real rings tgi welded on looked good (on regular 2500 Laramie wheels) I'm sure it could be done with p.wagon wheels
Sent from Canada
Deola2015
Post by Deola2015 » Sun Apr 10, 2016 3:58 pm
Ok I'm getting mixed reviews on the stock wheels, some say the backspacing will cause a 35x12.50 to run with an all stock suspension. I think different gens get different results, mine is a 2015. I like the stock wheels just fine, so if they will work I'll keep them. What's the verdict?
Post by adeluca73 » Sun Apr 10, 2016 4:20 pm
Deola2015 wrote:Ok I'm getting mixed reviews on the stock wheels, some say the backspacing will cause a 35x12.50 to run with an all stock suspension. I think different gens get different results, mine is a 2015. I like the stock wheels just fine, so if they will work I'll keep them. What's the verdict?
Stock OEMs are better than just about every other OEM, save for maybe original H1 (not the GM Brodozer H2/H3 wheels) wheels. Hutchinson offers true DOT approved Beadlocks, and they're not terribly expensive. I'll migrate to these one day after all my other dream list items are finished.
Here's the parent website:
http://www.hutchinsoninc.com/CMS/index. ... ion-Wheels
Here's the civilian market offering of their recreation beadlocks:
http://www.rockmonsterwheels.com/produc ... duct=dodge
gun45boat
Post by gun45boat » Sun Apr 10, 2016 4:36 pm
^^^^^^^ Agreed
Post by Will » Sun Apr 10, 2016 7:13 pm
X2
Deola2015
Post by Deola2015 » Sun Apr 10, 2016 8:58 pm
I agree, but will they rub if I make the jump to 35x12.50s on stock suspension?
Post by 2wagons1driveway » Mon Apr 11, 2016 9:06 am
They will rub the control arms and the swaybar probably but not a whole bunch. The higher number back space will keep you away from the fenders on full flex and put you to rub a bit more on the hard parts that can take the wear.
Sent from Canada
Post by Will » Mon Apr 11, 2016 9:12 am
He has a 2015, no control arms, You can fit 35x12.5 tires on stock wheels with slight rub on the radius arms at full turn (depending on tire, some may not even touch). Clears everything else.
Post by 2wagons1driveway » Mon Apr 11, 2016 9:37 am
Will wrote:He has a 2015, no control arms, You can fit 35x12.5 tires on stock wheels with slight rub on the radius arms at full turn (depending on tire, some may not even touch). Clears everything else.
he's got two radius arms hense control
Arms lol we are talking about 37's I thought? If just 35's it will be fine I would jump right to a 37" bfg or Mickey Thompson mtz tho... Looks so right with 37's on stock everything. But the swaybar will rub alittle also. Nothing to worry about or that black paint can't fix
Sent from Canada
Last edited by 2wagons1driveway on Mon Apr 11, 2016 9:38 am, edited 1 time in total.
Deola2015
Post by Deola2015 » Mon Apr 11, 2016 9:38 am
I should also mention that there was a pretty good amount of front inner fender trimming to accommodate the ADD bumper. I'm out on the farm now, and can snap a pic when I get back to pw if there isn't too much cow poo in there.
Deola2015
Post by Deola2015 » Mon Apr 11, 2016 12:20 pm
Here's the trimmed fenders, and a better side shot so you guys can see how far the bumper noses out in front. It's not as bad as that other pic made it look.
Post by OffroadTreks » Mon Apr 11, 2016 12:49 pm
I guess it's the photos, but it sure does look like it sticks down way low.
14PowerWaggy
Post by 14PowerWaggy » Mon Apr 11, 2016 1:42 pm
No rub with factory wheels and 35's... Depending on what brand of tire you go with a 37" will rub the rear fender liner and pinch seam... These will need to be trimmed a pretty good bit to make a true 37" tire fit with no lift...
gun45boat
Post by gun45boat » Mon Apr 11, 2016 4:35 pm
Is there a local Fab shop near you? Might be worth the money to cut and fab the lower part of that bumper up to match the height of the fairlead from the winch, might buy you an extra 6" of approach angle. From the pictures it looks like a 3 hour job of Fab work to make that thing have one more clearance. Maybe even cut that lower bar off too while you have the plasma out.. Keep up the good work;)
Post by adeluca73 » Mon Apr 11, 2016 11:34 pm
gun45boat wrote:Is there a local Fab shop near you? Might be worth the money to cut and fab the lower part of that bumper up to match the height of the fairlead from the winch, might buy you an extra 6" of approach angle. From the pictures it looks like a 3 hour job of Fab work to make that thing have one more clearance. Maybe even cut that lower bar off too while you have the plasma out.. Keep up the good work;)
^^^^ yep^^^ was going to suggest it, but felt bad suggesting hack off a big piece of your new bumper on your new truck, but...that bar has got to go
Deola2015
Post by Deola2015 » Tue Apr 12, 2016 3:27 pm
Ouch
