Reloaderguy's Build Thread
Re: Reloaderguy's Build Thread
Post by RustyPW » Mon Jun 16, 2025 7:52 pm
Reloaderguy wrote:
Sun Jun 15, 2025 11:38 pm
adeluca73 wrote:
Thu Jun 05, 2025 1:31 am
Yikes, $4k in tires😂
$2k. I got 7 years out of the 40's. I'm down to driving the truck once a month or two.
Hopefully I'll get to them on in July. I have to do the balljoints first.
Which ball joints you going with? I had the Carli's with 60,000 miles on them. They were still tight when I traded the PW in.
Post by Reloaderguy » Mon Jun 16, 2025 11:05 pm
EMF
Post by RustyPW » Tue Jun 17, 2025 7:01 pm
EMF
:rockon:
Re: Reloaderguy's Build Thread - Content Removed
Post by Reloaderguy » Mon Jun 30, 2025 8:30 pm
Reloaderguy wrote:
Tue Jul 16, 2019 2:11 pm
OffroadTreks wrote:
Tue Jul 16, 2019 11:07 am
Yeah but does it even run?
It runs great after its 45 day long annual lifter change.
I was reading back through this thread and thought I'd follow up on the lifters. All the BS from swapping lifters and hearing how defective they are was untrue. The issue is oil pressure at idle. I stopped using 0w-40 and the ticking went away. Chrysler was trying to use an oil that worked in the upper provinces and southern states. 10w30 and 10w40 works fine, no ticking. I installed a block heater and plug in when it's cold.
Post by Reloaderguy » Thu Jul 10, 2025 11:37 pm
Post by Bill2014 » Fri Jul 11, 2025 9:10 am
A sight to behold :cheers:
Post by Mule007 » Fri Jul 11, 2025 9:14 am
:cheers: Pics worth 1,000 words, 42” look good! Great looking truck!
Post by RustyPW » Fri Jul 11, 2025 6:53 pm
Nice! :rockon:
:winchmob:
