Which ball joints you going with? I had the Carli's with 60,000 miles on them. They were still tight when I traded the PW in.Reloaderguy wrote: ↑Sun Jun 15, 2025 11:38 pm$2k. I got 7 years out of the 40's. I'm down to driving the truck once a month or two.
Hopefully I'll get to them on in July. I have to do the balljoints first.
Reloaderguy's Build Thread
Re: Reloaderguy's Build Thread
EMFRustyPW wrote: ↑Mon Jun 16, 2025 7:52 pmWhich ball joints you going with? I had the Carli's with 60,000 miles on them. They were still tight when I traded the PW in.Reloaderguy wrote: ↑Sun Jun 15, 2025 11:38 pm$2k. I got 7 years out of the 40's. I'm down to driving the truck once a month or two.
Reloaderguy wrote: ↑Mon Jun 16, 2025 11:05 pmEMFRustyPW wrote: ↑Mon Jun 16, 2025 7:52 pmWhich ball joints you going with? I had the Carli's with 60,000 miles on them. They were still tight when I traded the PW in.Reloaderguy wrote: ↑Sun Jun 15, 2025 11:38 pm$2k. I got 7 years out of the 40's. I'm down to driving the truck once a month or two.
Re: Reloaderguy's Build Thread - Content Removed
I was reading back through this thread and thought I'd follow up on the lifters. All the BS from swapping lifters and hearing how defective they are was untrue. The issue is oil pressure at idle. I stopped using 0w-40 and the ticking went away. Chrysler was trying to use an oil that worked in the upper provinces and southern states. 10w30 and 10w40 works fine, no ticking. I installed a block heater and plug in when it's cold.Reloaderguy wrote: ↑Tue Jul 16, 2019 2:11 pmIt runs great after its 45 day long annual lifter change.
A sight to behold
Nice!
