Thanks guys for the suggestions. Will consider both. Don't want to derail the build. Looks good man.
2012 New to Me!
- SimonandSimonBeast
Re: 2012 New to Me!
I recently did some upgrades to the truck. I am currently at 64K, so I decided during my transmission service, I would upgrade the valve body. I swapped it out with a HD towing model from Worldwide Specialty parts. I got a new solenoid through them as well. Finally, I had them replace the pan with a PML aluminum pan. I wanted to see if it cools things off any better during my towing in the summer. So far the transmission seems a lot more "crisp." The shifts are smooth and the truck is running very well. I will get a chance to tow next week for hunting season, so I can see how it goes. The transmission pan is nice, and it does have a drain which will make things much more convenient to service next time.
I also ordered some Thuren Fox 2.0 shocks, swaybar links, and the XS front springs. I had not put any mods on the truck for a while, so I figured I would try these out. I could not quite justify the Kings based on price, and the Fox shocks have a good reputation. I can't wait until they arrive. I will post some pics when they get here.
Re: 2012 New to Me!
I put a Mag-Tec pan on my tranny and used a 1 ton tranny cooler from a Ram 3500 Hemi. This increased the capacity to something like 2.5 qts. i also plumbed in a tranny temp gauge into the pan.ghaugo wrote: ↑Tue Nov 15, 2022 7:28 amI recently did some upgrades to the truck. I am currently at 64K, so I decided during my transmission service, I would upgrade the valve body. I swapped it out with a HD towing model from Worldwide Specialty parts. I got a new solenoid through them as well. Finally, I had them replace the pan with a PML aluminum pan. I wanted to see if it cools things off any better during my towing in the summer. So far the transmission seems a lot more "crisp." The shifts are smooth and the truck is running very well. I will get a chance to tow next week for hunting season, so I can see how it goes. The transmission pan is nice, and it does have a drain which will make things much more convenient to service next time.
Re: 2012 New to Me!
Added a the Abel full bypass system and ran it to a switch panel. His system is outstanding. By far the best automotive accessory modification I have installed when it comes to directions and construction. Since I had the switch panel, I added some lights for off-roading. Wheel well lights, rear bumper lights, and large amber lights behind the grille. I forgot to post about these updates last summer when I finished them. Now I need get some photos added.
Re: 2012 New to Me!
Re: 2012 New to Me!
Re: 2012 New to Me!
I did the Abel full bypass as well. Great upgrade. Also, necessary for me since the SmartBar got fried with water incursion.
Sent from my SM-S928U using Tapatalk
Re: 2012 New to Me!
Your build out is coming along nicely, slow & steady!! Keep it up!!ghaugo wrote: ↑Mon Feb 17, 2025 9:49 amAdded a the Abel full bypass system and ran it to a switch panel. His system is outstanding. By far the best automotive accessory modification I have installed when it comes to directions and construction. Since I had the switch panel, I added some lights for off-roading. Wheel well lights, rear bumper lights, and large amber lights behind the grille. I forgot to post about these updates last summer when I finished them. Now I need get some photos added.
