Rusty's Build - 2008 POWER WAGON RC
pdavey
Re: Rusty's Build - 2008 POWER WAGON RC
Post by pdavey » Wed Mar 31, 2021 5:01 pm
Sent from my SM-G998U using Tapatalk
Performance Mods:
Other Mods:
Suspension/Protection Mods:
Style/Other Mods:
Post by RustyPW » Mon Apr 12, 2021 10:42 pm
Got the Kings installed. :rockon: They're 2.5 valved. They're softer then what I thought they would be.
Post by FirerescuePW » Sat Apr 17, 2021 6:40 pm
Damn it, for some reason I can't see your shock porn pics!
Post by RustyPW » Sat Apr 17, 2021 7:25 pm
I posted the pic's like I always do.
SimonandSimonBeast
Post by SimonandSimonBeast » Sat Apr 17, 2021 9:58 pm
Doesn't show on Tapatalk.
:rockon: :chug:
SimonandSimonBeast
Post by SimonandSimonBeast » Sat Apr 17, 2021 10:02 pm
On web view I can see it. Thick shafts...lol. what did you wrap them with?
:rockon: :chug:
SimonandSimonBeast
Last edited by SimonandSimonBeast on Sat Apr 17, 2021 10:02 pm, edited 1 time in total.
:rockon: :chug:
SimonandSimonBeast
Post by SimonandSimonBeast » Sat Apr 17, 2021 10:04 pm
:rockon: :chug:
Post by FirerescuePW » Sat Apr 17, 2021 10:18 pm
Well, would you look at that! I didn't even know there was such a thing as web view!
Nice shafts, Rusty!
Post by RustyPW » Sat Apr 17, 2021 11:17 pm
Cheap clear vinyl from Amazon.
Post by Mule007 » Sun Apr 18, 2021 10:56 am
Looks good! Web view was new to me as well!
Post by RustyPW » Sun Apr 18, 2021 8:21 pm
Did more work on the truck today.
1st pic. Got lots of suspension travel in the front.
2nd pic. Measuring for limit straps to keep the front springs from falling out. My 14.5' Carli straps are too short. Need around 16" straps.
3rd pic. Replaced the rear brake line with a 4" longer stainless brake hose. And added spacers to my air bags to keep them from pulling apart. The rear suspension has lots"of suspension travel too. Enough that my rear drive shaft hits the rear cross member.
4th pic. The PITA braKe line to brake hose junction. Sprayed the chit out of it with Blaster. The line wrench started to round off the flare nut. Got my small pipe wrench out, and worried that nut loose. Took me a while, but I got it. Got great brake pedal now.
SimonandSimonBeast
Post by SimonandSimonBeast » Mon May 03, 2021 11:45 am
RustyPW wrote:Did more work on the truck today.
Did you ever consider the Daystar cradles so the bags are only attached to the frame?
:rockon: :chug:
Post by RustyPW » Mon May 03, 2021 5:31 pm
When I got the Carli long travel air bags. The Daystar cradles wasn't out yet. Those were another 4 or 5 yrs down the road before they came out with them. The only other option was the standard short travel Firestone air bags at that time.
Post by RustyPW » Mon May 03, 2021 5:37 pm
Talked to Don about limit straps with the King shocks. He said they are not needed with my set-up. Asked about topping out the shock and damaging it. He said not to worry about that. The shocks are built to handle it. The only reason for a limit strap was if the springs came loose during full extension. And I'm almost there. So no limit straps for now.
SimonandSimonBeast
Post by SimonandSimonBeast » Mon May 03, 2021 6:33 pm
:rockon: :chug:
