Rear reverse light pods
Posted: Sat Nov 09, 2019 11:25 am
by Easttnrhino
I am wanting to install some light pods in my rear bumper and just wire them up so when I put it in reverse they come on. What would be simplest way to wire them? Thanks
Re: Rear reverse light pods
Posted: Sat Nov 09, 2019 12:04 pm
by Oilbrnr
Reverse wire on the 7 pin wiring harness is what I did for some Rigid diffused pods.
Posted: Sat Nov 09, 2019 12:53 pm
by Easttnrhino
Do you remember the wire color and it looks like it might be the middle wire does that sound right
Posted: Sat Nov 09, 2019 5:57 pm
by SeppW
I'd wire them on their own circuit with the reverse light triggering a relay or on a switch in the cab. The center pin on 7-pin connector is supposed to the aux/back up light connection. Not sure of the wire color, probably, blk, yel, or purple
Posted: Mon Dec 02, 2019 4:09 pm
by SimonandSimonBeast
Have you considered a reverse lamp upgrade? Headlight Revolution has 1,000 lumen LED upgrade bulbs for $89 a pair. Plug and play right in place of your current bulbs.
Posted: Mon Dec 02, 2019 4:34 pm
by Easttnrhino
I had already done some cheap e bay bulbs and they were quite a upgrade.
Posted: Mon Dec 02, 2019 10:09 pm
Easttnrhino wrote:I had already done some cheap e bay bulbs and they were quite a upgrade.
Damn, you could get a tan behind that truck at night.Image
Posted: Thu Jan 02, 2020 5:06 pm
by Havn2muchfun
Rigid sells a wiring kit just for this. Has a 3 position switch. Off, on, and auto which makes them work when put in reverse.
