Rear reverse light pods
Easttnrhino
Post by Easttnrhino » Sat Nov 09, 2019 11:25 am
I am wanting to install some light pods in my rear bumper and just wire them up so when I put it in reverse they come on. What would be simplest way to wire them? Thanks
Enjoying beautiful east TN
Oilbrnr
Re: Rear reverse light pods
Post by Oilbrnr » Sat Nov 09, 2019 12:04 pm
Reverse wire on the 7 pin wiring harness is what I did for some Rigid diffused pods.
'16 with '17 FWC
Easttnrhino
Post by Easttnrhino » Sat Nov 09, 2019 12:53 pm
Do you remember the wire color and it looks like it might be the middle wire does that sound right
SeppW
Post by SeppW » Sat Nov 09, 2019 5:57 pm
I'd wire them on their own circuit with the reverse light triggering a relay or on a switch in the cab. The center pin on 7-pin connector is supposed to the aux/back up light connection. Not sure of the wire color, probably, blk, yel, or purple
SimonandSimonBeast
Post by SimonandSimonBeast » Mon Dec 02, 2019 4:09 pm
Have you considered a reverse lamp upgrade? Headlight Revolution has 1,000 lumen LED upgrade bulbs for $89 a pair. Plug and play right in place of your current bulbs.
:rockon: :chug:
Easttnrhino
Post by Easttnrhino » Mon Dec 02, 2019 4:34 pm
I had already done some cheap e bay bulbs and they were quite a upgrade.
SimonandSimonBeast
Post by SimonandSimonBeast » Mon Dec 02, 2019 10:09 pm
Easttnrhino wrote:I had already done some cheap e bay bulbs and they were quite a upgrade.
Damn, you could get a tan behind that truck at night.Image
:rockon: :chug:
Havn2muchfun
Post by Havn2muchfun » Thu Jan 02, 2020 5:06 pm
Rigid sells a wiring kit just for this. Has a 3 position switch. Off, on, and auto which makes them work when put in reverse.
2018 Power Wagon.35/12.5/17 Yokohama Geolander X-MT. Warn Ascent rear bumper. Pulsar piggyback.
