2017 Ram Tradesman Power Wagon
Post by TwinStick » Thu Apr 20, 2017 7:21 pm
http://www.castilonechryslerdodgejeep.n ... ccc0bb.htm
I have briefly looked at this truck. No PW stickers/decals/emblems on it anywhere. It DOES have the 6.4L, Ram Box, spray in bed liner and a tonneau cover. $6500 off with rebates & incentives. And yes, that is NOT a proper pic. The pic they posted is of a CTD.
yooper68
Re: 2017 Ram Tradesman Power Wagon
Post by yooper68 » Fri Apr 21, 2017 8:02 am
Nice to see you can still get RamBoxes on the Tradesman Power Wagon. That is a decent price!
I tried out a 2014 or 2015 model basically identical to that 2 years ago. It was minus the tonneau cover & spray-in bedliner. Can't recall if it had the 5.0 radio or "parksense". I do remember that the truck rode very nice, even on rough blacktop.
Trucks: 2003 4x4 Dodge 3/4 ton, 1972 4x4 Ford 3/4 ton (factory hi-boy), shopping for new Power Wagon (or may wait for 2020 model? - 75th year special edition?)
