DamageWagon's Build - 2011 "AdventureWagon"
Re: DamageWagon's AdventureWagon
Post by Low_Sky » Fri Mar 10, 2017 11:46 am
My old Cheby Silverado lost a unit bearing on a road trip from Utah to Montana once. The problem revealed itself initially with an ABS fault. I found an auto parts store in Bozeman, read the code, and thought surely I could make it home. Nope! I limped it off the highway an hour north of SLC, hoping the wheel wouldn't fall off. I got to spend the night in a hotel and change the unit bearing in a parts store parking lot four hours from home. It's probably not a bad idea to have a spare and the tools to change it out with you on such a long trip.
Post by DamageWagon » Fri Mar 10, 2017 12:37 pm
Crap, that's great to know Low Sky. What warning signs do you get? Does it go straight to making your wheel wobbly and killing your steering?
Sent from my safe space
Post by Bill2014 » Fri Mar 10, 2017 2:27 pm
I've had 3 unit bearings go on two different Chevys. In all three situations, the abs would start acting up at low speed. That was my indicator that one of the unit bearings was going. I would be braking, and slowing down for a red light, and when I got down to about 5mph, the abs light would come on and the brakes would barely work and I would have to veer off to keep from hitting the cars ahead. :D I would replace the unit bearing some time in the next 500 miles and never had a problem other than the abs braking.
Post by Low_Sky » Fri Mar 10, 2017 6:01 pm
I never had misbehaving brakes, just the ABS fault (I'm guessing heat killed the sensor). Then I had bearing noise which was worse when turning. The noise kept getting worse and eventually I started feeling it in the steering. ABS fault light to total destruction in ~350 interstate miles.
Post by DamageWagon » Sat Mar 11, 2017 1:57 pm
I'm going to give a shout out to Paul at CJC for giving me some great technical advice on ball joints, giving a down to earth opinion on the joints I wanted and for forcing me to watch a video of him doing BJ's. Also for trying to find me a unit bearing.
To tgibbs on DTX for letting me come over at 9pm on a Friday and working nonstop with me until 2am to swap ball joints with his tools and for giving me good advice and teaching me a few things in the process, and trying to find me a unit bearing.
And to the Mopar steering stabilizer, that with 160,000 miles and three rock strikes and a leaky seal somehow stopped me from getting death wobble so that I could drive 60 miles on the freeway to Tristan's place when I couldn't make it five miles on the street without my tires shaking off the ground without the stabilizer.
It's a little darty now but that should go away as the joints break in. It was already feeling better on the drive home. Funny enough I still got death wobble on the way home with a few bad freeway sections so I still have a few things to check out, but it was nowhere near as bad as before and it went away on its own. I'm pretty happy.
Post by Reloaderguy » Sat Mar 11, 2017 2:00 pm
DamageWagon wrote:and for forcing me to watch a video of him doing BJ's.
I don't think I want to watch a video of Paul doing BJ's.
Post by DamageWagon » Sat Mar 11, 2017 2:11 pm
He does not sound happy in the video. He was doing all the work and describing it as he went Image
Post by BoldAdventure » Sun Mar 12, 2017 1:43 pm
You are the man. That is not an easy job. I am not envious of it. Glad you managed to get that worked out before your trip. :cheers:
Hey question about your sliders, I assumed they aren't finished yet? You installing rails in-between the outside rails?
Post by DamageWagon » Sun Mar 12, 2017 6:06 pm
Thanks Mike, it was definitely easier than I imagined but having a buddy who has done them and has a nice BJ press made a big difference. Ive had the brake/rotor assembly off more times than I care for now.
The sliders are not done, you are correct. I want to add short support tubes between the rectangular tube and the nerf tube. There's no way I'm getting done in time for the trip though, that is just how they will be during Moab I think.
Post by DamageWagon » Sun Mar 12, 2017 11:34 pm
Well to top off the ball joints, I got to have even more fun last night. About two months ago I pumped royal purple grease through my ABS sensor holes in the wheel bearings to attempt to grease them. About a week later my ABS light dinged. So a few days ago I was doing the tie rod on the truck and decided to pull the ABS sensor and look inside, and what do you know, on my passenger front bearing the grease inside is brown from pressure (confirming that the ABS hole does grease the bearing) and there are metal flakes everywhere inside. Drivers side the grease was brown but no flakes and no ABS error. So we are leaving to tow a trailer 3600 miles, a trip to NAPA was in order. They carry the good SKF bearing as their standard. $300 later I have a new bearing. In she went! Holy crap that axle but was tight hehe
In addition to the bearing I also still had death wobble after changing ball joints. At this point I was running out of things to check, so I decided to do a driveway alignment. I go to line the truck up straight, look at both tires and realize HOLY CRAP they're pointed at each other! Image Hop under with a tape measurer, 1.25" of toe-in. Holy crap no wonder I have DW! The tires are fighting each other to death! Funny I never felt anything odd when my ball joints and tie rod and drag link were all shot, maybe massive toe is the pro method to make you feel nothing? So I adjusted that to 0.125" toe and it drives with no wobble. Image
Post by nts007 » Sun Mar 12, 2017 11:58 pm
So our deadly wobble was actually the rh tire trying to send you into traffic and the lh tire saving your life. Balance...
Post by Colibri » Mon Mar 13, 2017 8:37 am
That's some crazy stuff with the alignment :jawdrop:
I'm glad the bj's went well, I had a feeling you'd knock it out relatively easy, good job!
Post by olyelr » Mon Mar 13, 2017 12:01 pm
Nice job on the repairs! Your in for a much safer trip now hahahah. Im sure you did, but hopefully you used liberal amounts of anti-seize when reinstalling everything.
Post by DamageWagon » Mon Mar 13, 2017 12:10 pm
olyelr wrote:Nice job on the repairs! Your in for a much safer trip now hahahah. Im sure you did, but hopefully you used liberal amounts of anti-seize when reinstalling everything.
I used a California Liberal amount of anti-seize on everything. Image
Every bolt on my truck gets either anti-seize or loctite. If I have to spend four hours with s hammer and a torch and a key bar to get my front end disassembled, I would prefer to spend about five minutes the next time.
Post by olyelr » Mon Mar 13, 2017 12:19 pm
Exactly! Nothing worse than an hour job takkng 3 because of stuck bolts/parts.
Post by Reloaderguy » Tue Mar 14, 2017 10:27 am
What was causing the rough idle?
Post by DamageWagon » Tue Mar 14, 2017 12:12 pm
Did you know that, when you pull your valve cover and bump an AC line and leak all of your refrigerant out, that your electric fan no longer works? Yep, the electric engine fan is controlled by the CANBUS and a required setting is for the AC system to have a certain pressure inside it for that fan to run. So I'm towing with no electric fan, although it hasn't mattered. I made it up the Grapevine no issues. Going to get it fixed before we start our trip since it's the low speed stuff that the electric fan plays into.
@reloader
Replaced O2 sensors and dc'ed battery for thirty minutes. That made no change. Funny enough, I was welding the shock resi mounts to the frame and dc'ed the battery overnight and after that the truck runs SO SMOOOTH. It still has occasional roughness, but never have I felt it run smooth as butter like this. No shake, runs awesome. O2's may not have been the fix but resetting the battery that long ended up resetting the transmission learn points. Or some weld current got to the PCM lol
yellowranger1
Post by yellowranger1 » Tue Mar 14, 2017 12:30 pm
Nice timing with the AC bust! Just as it got hot as balls out here again! I feel your pain, we bumped a line on my dad's old megacab a few years back right before a turnaround trip to haul a trailer back from vegas... mid July. Leather seats, 110*, and Vegas Sunday traffic was not a good time!
Post by DamageWagon » Tue Mar 14, 2017 1:50 pm
We were taking my 2001 to the Grand Canyon for 4th of July a few years ago. Going through the Virgin River Gorge outside St George Utah the bridges had been damaged by a flood so they had all traffic down to one lane each way. We were stop and go, max 2mph for almost 4 hours in 108 degree heat. Leather seats. No electric fan on the cummins so as soon as I turned the AC on it started overheating, seven in neutral revving the engine it was just too much. It got to the pointing it out of the truck and opened the hood partway. That was fun haha
Post by Reloaderguy » Tue Mar 14, 2017 1:56 pm
DamageWagon wrote:Did you know that, when you pull your valve cover and bump an AC line and leak all of your refrigerant out, that your electric fan no longer works? Yep, the electric engine fan is controlled by the CANBUS and a required setting is for the AC system to have a certain pressure inside it for that fan to run. So I'm towing with no electric fan, although it hasn't mattered. I made it up the Grapevine no issues. Going to get it fixed before we start our trip since it's the low speed stuff that the electric fan plays into.
@reloader
The electric fan is for the AC, the compressor isn't going to run without line pressure so the fan will default off.
I'm glad you got the engine sorted, the cam diagnosis sounded iffy.
Post by DamageWagon » Mon Mar 20, 2017 6:25 pm
@Reloader, what I noticed was that the low speed fan is controlled only by the AC system, but the high speed fan is triggered by the thermostat. My truck hit 221 degrees a few times but then would immediately begin cooling and would never go above 219 again due to the electric fan being on. It's nice to know I still have reserve cooling.
Post by DamageWagon » Mon Mar 20, 2017 6:26 pm
I am sick and tired of death wobble. I need some opinions. So the DW came back, probably a dozen times with the trailer loaded and probably 50 times so far with the trailer unloaded or no trailer. The steering stabilizer is keeping it on the road but I'm pissed off and need it fixed. I have not been able to get an alignment since we keep having to stay on the road. Currently in Coeur d'Aleine.
What I have done:
- new EMF ball joints, now broken in
- new NAPA tie rod
- EMF drag link, broken in and adjusted
- blown Mopar steering stab
- 34" Toyo MTs that are slightly more worn on the inside from driving on old BJs but are almost new
- new passenger front wheel bearing
- original control arms, pretty shot
- old style Carli Trackbar, bushing appears to move about 1/16"-3/32" using power steering driveway test. New heim.
- original Mopar big box
I had the girlfriend turn wheel side to side with engine on and crawled underneath. I couldn't see anything moving or popping, only the Trackbar bushing had any movement but even it seemed like 1/16" or so. I can turn the steering wheel a little bit before it takes slack, I think that's the steering u-joint that's right by the firewall? Gearbox looks tight, maybe it isn't original.
Possible ideas:
- Trackbar bushing may be shot. I compared the bushing housing ID to the dimension Aaron sent me after the Thren bushings didn't fit and my bar is 0.025" oversize. Don't think it should be that way but I don't know how it would enlarge like that. It is round, not ovaled.
- NAPA tie rod. It is a greaseable bar. Maybe the TREs are dry and the grease is supposed to fill a void?
- communist gremlins in my steering
- ball joints are broken in and any vertical loading/unloading movement is causing the lower ball joint to move into free space and allow slop
Post by Reloaderguy » Mon Mar 20, 2017 8:53 pm
Is your girlfriend sick of your truck yet?
Post by DamageWagon » Mon Mar 20, 2017 10:43 pm
Reloaderguy wrote:Is your girlfriend sick of your truck yet?
Without quoting her... Yeah that sums it up :cash: :cash: :cash:
Post by FirerescuePW » Mon Mar 20, 2017 10:50 pm
I don't think the lower BJ should have up/down movement. The upper will show up/down through the turning cycle. It really just acts as a pin.
My next thought would be track bar bushing, then control arm bushings. This order is simply due to cost and ease of replacement. A true alignment may help, too.
