Brakes ......
Re: Brakes ......
Post by TwinStick » Wed Mar 01, 2017 3:49 pm
Brake lines are on, total brake job is done. Rotors, caliper's & pads on all 4, 2 new front brake lines, 1 new back brake line. Pedal is consistent every time. Stops wicked fast. Life is good. :lol:
So, the new brake lines fixed the "pump once to have good brakes" issue ! :rockon:
Re: Brakes ......
Post by DamageWagon » Wed Mar 01, 2017 3:53 pm
That's great! Glad you're liking the new brakes Twin. I might need new lines then.
Sent from my safe space
Re: Brakes ......
Post by TwinStick » Wed Mar 01, 2017 4:02 pm
For some reason, I thought it was just the front lines. Guy said there was 1 rear as well, so he put it on. Cool ! Always good to get more than you expected. :rockon:
Pit Slave
Re: Brakes ......
Post by Pit Slave » Wed Mar 01, 2017 5:08 pm
I don't like saying I told you so, so I will let someone else say it on behalf of me. :)
Redman1973
Re: Brakes ......
Post by Redman1973 » Fri Mar 03, 2017 6:01 am
TwinStick wrote:Brake lines are on, total brake job is done. Rotors, caliper's & pads on all 4, 2 new front brake lines, 1 new back brake line. Pedal is consistent every time. Stops wicked fast. Life is good. :lol:
TwinStick,
Can you post all the part numbers for your brake job? I will need A brake-over on OX within the year :sick:
Power Wagon Registry #47
- Thuren steering upgrade
- Snorkel
"The" Wifes Car
"Liam" 2018 Jeep Cherokee Latitude
My Toy
"VISCO" 2013 196CC Tidewater
Re: Brakes ......
Post by TwinStick » Sat Mar 04, 2017 12:44 pm
http://www.cjcoffroad.com/Carli-Dodge-R ... -d6bbl.htm
Those are the ones I used. 6" over stock, from CJC Off Road.
As far as the brakes, I got this: https://www.summitracing.com/parts/pwr- ... l/ram-2500 From Summit Racing.
It includes Rotors, pads & calipers for all 4.
