SOLD - RER Radio Low Speed CAN bus, with Lockpick
Moderator: AceMan
Locked
AceMan
Site Admin
Site Admin
Post by AceMan » Sat Aug 22, 2015 4:05 pm
This came out of a 2008 Dodge Charger. I had it in my 2006 for a few years. You may have read my build thread on it in DT back in 2010. Because I wanted my mirror UConnect to work, which this didn't support, I put the original REC back into it. This will work in any Dodge 2006 and newer car or truck with the Lockpick to adapt it into the system. But you must get your own microphone, which are cheap.
Or it can be used as a direct swap for any vehicle with an RER low speed CAN bus. To give you an idea, the high-speed CAN bus didn't start coming out until the 2010 Dodge Ram trucks. CAN = Computer Area Network.
I'll eventually be putting this on eBay, which may give me a few more bucks, but I thought to offer it here to our community, first.
New, the RER is about $400 to $500, depending on who you buy it from.
New, the Lockpick is about $300.
$400 total package, plus shipping (UPS).
I'll eventually put it on eBay for $500 plus shipping
BlkWgn
Re: RER Radio Low Speed CAN bus, with Lockpick
Post by BlkWgn » Sat Aug 22, 2015 6:39 pm
:cash: Thanks for waiting until a day after I order a new fridge for the truck and am completely broke.
AceMan
Site Admin
Site Admin
Post by AceMan » Sat Aug 22, 2015 7:01 pm
BlkWgn wrote::cash: Thanks for waiting until a day after I order a new fridge for the truck and am completely broke.
Oops. Sorry.
azracer
Post by azracer » Sun Aug 23, 2015 1:08 am
I'm curious what you plan to get to replace it?
I did not get the RER radio because I also wanted my U-connect Mirror to work but never looked into any other options.
AceMan
Site Admin
Site Admin
Post by AceMan » Sun Aug 23, 2015 1:00 pm
I had an REC, got another REC with the camera option, and the REC Lockpick. I don't think any options exist to use the UConnect mirror other than if you can pinout the microphone leads. Then again, if you disconnect the harness to the mirror, the day/night feature no longer works.
So, I have a non-camera option REC for sale, too, without the nav DVD. $350 plus shipping.
azracer
Post by azracer » Sun Aug 23, 2015 3:59 pm
AceMan wrote:I had an REC, got another REC with the camera option, and the REC Lockpick. I don't think any options exist to use the UConnect mirror other than if you can pinout the microphone leads. Then again, if you disconnect the harness to the mirror, the day/night feature no longer works.
So with the REC has a camera option that you can lock pick to use forward and rear cameras as well as DVD while under way. The U-connect rear view mirror then works on this REC setup? Is the only difference no Nav... or do you lose other features? It still has aux in as well as USB and a hard drive correct? Are the connectors the and pin outs same for the OEM REF that I have and the REC. or is an adapter needed? Did you find a tutorial on line to help you figure out what was needed and what options you could use? Link?
What PN is the one I want to find.
Mule
Post by Mule » Sun Aug 23, 2015 5:04 pm
*controller area network
AceMan
Site Admin
Site Admin
Post by AceMan » Sun Aug 23, 2015 5:48 pm
There are two REC versions: one with the camera, and one without. The Lockpick will allow you to connect a 3rd camera, because if you don't have one, you won't have that specs harness and plug. That's partially why I got the camera REC and Lockpick. Also, I'm connecting TPMS to the aux1 video on the Lockpick. Cool addition. I'll post about that when I get it together.
AceMan
Site Admin
Site Admin
Mule wrote:*controller area network
Thanks. :-)
azracer
Post by azracer » Sun Aug 23, 2015 7:07 pm
That would be great
Thanks!
AceMan
Site Admin
Site Admin
Post by AceMan » Sun Aug 23, 2015 10:11 pm
azracer wrote:That would be great
Thanks!
Heads up, this is the one I was looking at. It has an AV RCA output that plugs into a DVD or other video player. The Lockpick gave me two additional inputs for additional cameras or.other video sources. This style screws and locks on to the current Schrader valve. I haven't quite decided to get it yet and may get the internal sensor version if I get new tires, which u think the transmitters are interchangeable. Still in research mode...
Rupse Universal TPMS Tire Pressure Monitor System with 4 External Sensors Displayed on Your DVD Monitor http://www.amazon.com/gp/aw/d/B00MQL4LS8?psc=1
Power Wagon Owner's Club #110
Black '06 PW QC
Image Image Image
Post by Colibri » Sun Sep 06, 2015 2:53 pm
I want this! I'll pm you later today for payment info.
Locked
