Mopar Connector Repair Parts Link
Post by coder » Thu Feb 19, 2015 5:59 pm
Find all your factory replacement electrical connectors at Mopar Connector Repair Parts.
http://connectors.dcctools.com/home.htm
Pit Slave
Re: Mopar Connector Repair Parts Link
Post by Pit Slave » Thu Feb 19, 2015 8:51 pm
I stickied this. Good find!
Takingatrip1
Post by Takingatrip1 » Wed Feb 25, 2015 2:36 am
Connector issue
When taking my center stack apart i broke the little locking clip on the grey connector for the LOCKERS !! Its in the socket now, the lockers work but miles of vibrations are bound to cause a problem.
Is the connector replaceable ? should i just super glue the plug and cut the wires and attach bullet /spade connectors ? Duct tape ?
'11 Powerwagon
'11 FWC Hawk Camper
Post by FirerescuePW » Wed Feb 25, 2015 6:33 am
Can you just wrap a wire tie around it?
Pit Slave
Post by Pit Slave » Wed Feb 25, 2015 9:09 am
Takingatrip1 wrote:Connector issue
You can replace the connector housing on the wire without cutting the wires.
The silicone seal ring will hold the majority of the connection and you can use a tie wrap (zip tie) to hold the two ends together.
Takingatrip1
Post by Takingatrip1 » Wed Feb 25, 2015 9:16 am
The connector behind the dash? Hmm I'll look at it again this weekend.
'11 Powerwagon
'11 FWC Hawk Camper
jeep_boy02
Post by jeep_boy02 » Wed Feb 25, 2015 9:24 am
Has Morgan seen this? Is that 3rd gen connector for his locker bypass he's been searching for available there?
Pit Slave
Post by Pit Slave » Wed Feb 25, 2015 10:31 am
Takingatrip1 wrote:The connector behind the dash? Hmm I'll look at it again this weekend.
Behind the dash, I would leave as is unless you're planning on doing sustained high speed off road runs.
Takingatrip1
Post by Takingatrip1 » Wed Feb 25, 2015 2:36 pm
maybe a little duct tape strap and a zip tie then. Not planning on any high speeds offroad i take it easy offroad usually , but the los Angeles fwys are about as smooth as a crappy fire road
'11 Powerwagon
'11 FWC Hawk Camper
Pit Slave
Post by Pit Slave » Wed Feb 25, 2015 3:27 pm
No duct tape, use vinyl electrical tape. Some duct tape manufacturers use a formulation in the adhesive that reacts with the insulation on the wire and dissolves it causing a potential short.
"potential short" = "potential fire"
Takingatrip1
Post by Takingatrip1 » Wed Feb 25, 2015 8:06 pm
wow...thanks for that man ! I'll just leave it alone :idea:
'11 Powerwagon
'11 FWC Hawk Camper
myoung84
Post by myoung84 » Thu Mar 05, 2015 10:56 am
jeep_boy02 wrote:Has Morgan seen this? Is that 3rd gen connector for his locker bypass he's been searching for available there?
I've seen it, and no, none of the connectors I need for the 3rd gens are available... :(
GunniPWguy
Post by GunniPWguy » Tue Mar 17, 2015 2:23 pm
Bummer!
fbenross
Post by fbenross » Tue Mar 17, 2015 10:01 pm
I didn't see locker connectors for my 06
Post by adeluca73 » Thu May 21, 2015 12:23 am
Great site, thanks!!
Kinnettic
Post by Kinnettic » Tue Jan 16, 2018 5:59 pm
If people need connectors, I can get a wide variety of them from non-Mopar sources. Usually need some good pics to be able to identify and track them down, but not all of them. And some of them unfortunately have substantial minimum orders in the range of $100 or more depending on who made it and lots of other random reasons.
