Off and On Road Lights
Cactus Red
Re: Off and On Road Lights
Post by Cactus Red » Mon Dec 29, 2014 11:44 am
If I was in the market for lights again, I'd be looking at either the KC or Vision X high wattage round LED's. It's all about the reflector - bigger is better.
Sent via Carrier Pigeon
Post by adeluca73 » Mon Dec 29, 2014 12:46 pm
adeluca73 wrote:I've seen a lot of 3rd Gen posts covering upgrade replacment bulbs for the fogs & for the main lights. Has anyone cracked the code (part #'s & make/brand) for 2013-2015 PW replacements/upgrades ?
^^^^^ anyone ^^^^^?????
Juday
Post by Juday » Mon Dec 29, 2014 12:49 pm
You're right. That's why I want the 9.5" light on the front!
One thing that does limit me is the depth of the light assembly. Since I got the optional "animal guard" on the front of the bumper, that limits me to not much more than a light that is 4.5" to 5" deep (unless I really want it to hang off of the front, which I don't).
2012 RAM Power Wagon
Dark84
Post by Dark84 » Mon Dec 29, 2014 1:46 pm
Adeluca73 is this what you were looking for?
http://www.xenondepot.com/2014-2500-hid ... /30208.htm
Sent from my mind to yours.
Post by 2wagons1driveway » Mon Dec 29, 2014 2:55 pm
Juday wrote:You're right. That's why I want the 9.5" light on the front!
like I said look up GG lighting! 200-300$ for a 30-40" light bar... More lumens for the money's I'm pretty sure their lifetime warranty too! Hyperion is another good one too for the $$$.
Sent from somewhere your not
Dark84
Post by Dark84 » Mon Dec 29, 2014 3:56 pm
Decided to check out some of gg lightings lights. Looked pretty good but when I checked for reviews online I found this:-(
http://www.ripoffreport.com/r/gg-lighti ... ia-1053692
Post by 2wagons1driveway » Mon Dec 29, 2014 4:38 pm
Anything on Hyperion both of those guys were good and fast to deal with
Post by 2wagons1driveway » Mon Dec 29, 2014 4:40 pm
Deffinately won't be dealing with gg lol maybe rtx or rigid
Pit Slave
Post by Pit Slave » Mon Dec 29, 2014 7:11 pm
This is good to know. What I'm working on is going to be about 4" to 4¼" in depth. I'm trying to possibly drop that down to just over 3" total.
Post by adeluca73 » Mon Dec 29, 2014 8:31 pm
Dark84 wrote:Adeluca73 is this what you were looking for?
http://www.xenondepot.com/2014-2500-hid ... /30208.htm.
Awesome start, thanks!!
So I want to upgrade the fogs & saw these top of line bulbs, they are rated at 35W draw, but are 55W equivalent rated:
http://www.xenondepot.com/9006-HID-Kit- ... t-9006.htm
Looks like there's a ballast module for each light, are these plug-n-play? Do you just zip tie the ballast modules somewhere inside the bumper?
Juday
Post by Juday » Tue Dec 30, 2014 9:05 am
Do you care to elaborate any on this?.......... :popcorn:
Cactus Red
Post by Cactus Red » Tue Dec 30, 2014 10:31 am
Guys, this is drifting off it's intended purpose - to show installs and how they actually work.
So, lets try to do only that if we can!
Pit Slave
Post by Pit Slave » Wed Dec 31, 2014 6:09 pm
Not yet, stay tuned...
08TwinStickPW
Post by 08TwinStickPW » Mon Feb 16, 2015 9:48 am
Finally ordered a set of 6" KC gravity's in driving pattern, stay tuned for pics.
They will be replacing the long range Daylighter knockoffs I converted to HID I have on custom mounts behind my grill. I only have $60 into them and while they do have decent output, however the pattern is shitty.
Cactus Red
Post by Cactus Red » Mon Feb 16, 2015 10:23 am
Saw some of the new LED large reflector lights at the Parker 425 this year. I think you will be pleased!
Graveltravels
Post by Graveltravels » Wed Feb 18, 2015 4:50 pm
So my ARB's are hooked up. This first picture is the low beam, HID's factory on the 2015
Graveltravels
High beams.
Graveltravels
Post by Graveltravels » Wed Feb 18, 2015 4:51 pm
And the ARB's. One spot, one flood. I am very impressed with them.
Juday
Post by Juday » Thu Feb 19, 2015 8:23 am
Looks like they're aimed too low, or is it just my imagination? Definitely bright, though!
Graveltravels
Post by Graveltravels » Thu Feb 19, 2015 9:47 am
The spot is aimed properly, the flood is another story. The patch isn't so bad in real life, but I've actually tipped it back to lessen the blinding spot on the ground. If I had it to do over, I'd probably go with two spots. I may be buying another pair for the jeep, if I do, it'll be two spots, and then move the flood to the jeep, and run the spots on the truck.
Post by TwinStick » Fri Feb 20, 2015 2:52 am
I call that "light backwash". Almost too much light. :lol: Never thought i would live to see the day when TV's were too big & too clear & aux vehicle lighting was too bright !!! LOL :lol:
That light would be perfect without the bright spot there. Looks very evenly spread otherwise.
Traded to 2019 ZR2, Red.
Graveltravels
Post by Graveltravels » Fri Feb 20, 2015 8:54 am
I'll take a pic of the angle I had to tip the flood to prevent even more backwash. I agree, I never thought I'd see the day when too much lighting actually happened. Another thing I've noticed, is on the narrower country roads, the reflective signs are blinding!!
Cactus Red
Post by Cactus Red » Fri Feb 20, 2015 9:35 am
That's common - backscatter is much more pronounced, especially with a flood pattern. The driving pattern on my HID's does the same thing because of the wide flat beam they produce.
joshet89
Rigid Dually Fog assembly
Post by joshet89 » Fri Feb 20, 2015 10:10 am
There was someone asking about if any one has installed the rigid dually fog light bracket. I installed the brackets and 2 sets of duallys (1 set of spot and 1 set of flood) on my 2013 and then removed and re-installed on my 2014 as well. I have been very happy with them and use them on my commute home from work which is mostly dark county roads and almost always driven after dark, at least that is what it feels like this time of year :angry: . The install was very easy and took less than an hour. I wanted to make sure they worked with the factory fog light switch so I purchased a fog light extension so I could solder the 2 connectors from the duallys to the extension and then just plug the whole assembly into the factory plug. The extension I purchased needed some extra water proofing so I put liquid electrical tape around the back of the wires going into the plastic housing. When attaching the duallys to the bracket I installed the spot on the inner part of the bracket and the floods on the outer part. I had marked my factory fog light beams on my garage door and made sure the spots where a little below the factory spots and have very even and wide disbursement.
have to attach the duallys to the bracket before attaching the bracket to the truck.
cut off the male end and soldered to the dually connectors
both dually connectors soldered to the extension
wiring harness.jpg (25.64 KiB) Viewed 5400 times
completed install
from truck to pile at the end of the road is 240 feet with no lights on on the truck
just the rigids turned on
rigids and low beams
just high beams, since the rigids are in the factory fog harness they will turn off with the high beams. Since the install I have not had a need for the high beams.
stubiePW
Post by stubiePW » Fri Feb 20, 2015 5:51 pm
Sweet. I've been looking at doing that mod but wasn't sure. Loooks good
