Diff Temp video
Re: Diff Temp video
Post by olyelr » Thu Oct 04, 2018 2:37 pm
BoldAdventure wrote:
Thu Oct 04, 2018 10:20 am
This video series has been really informative.
Yes, I agree. Very neat to watch. I am really intrigued to see the results of the next episode, with actual diff temps for each scenario.
Re: Diff Temp video
Post by RustyPW » Thu Oct 04, 2018 6:07 pm
I was wondering about my RockCrusher diff covers. Found some pictures when I installed them. I can see the higher fill hole. :shock: The inside shape is close the the factory. Just changed the fluids in both diffs back in June. 3 qts in the front and 6 qts in the rear. Thinking on taking some out.
Mods to the PW; Nerffed Mopar RockRails, Wheel Well Liners, Bushwacker Pocket Fender Flairs, Garvmin dezl 560LMT GPS, Power Wagon Winch Kit, Line X Ultra Bed Liner, PIAA Headlight Bulbs, PIAA 580 Driving Lights (135 watt), PIAA 520 Fog Lights (135 watt), PIAA 520 ATP Off-Road Lights (135 watt), Locker Bypass, Modifed Rockcrusher Diff Covers, Mopar Utility Bed Rails and Tool Box, Warn Winch Wireless Remote Control, "el-cheapo" Inclinometer, Airaid CAI, Winch TPS Bypass, 35" Toyo's, Mopar Spare Tire Lock, 'T' Steering Linkage, Modifed PSC Steering Brace, P3 Brake Controller, Modifed Fusion "mall crawler" rear bumper , PIAA 1500 Back-Up Lights, 1Ton HEMI Tranny Cooler, Leer 100XR Bed Cap, Factory Tow Mirrors, CenterLine Rims 17x9-5.25 BS, Mag-Hytec Tranny Pan, AutoMeter Gauges, PSC Extreme Hydro Assist Steering, Carli G2 Track Bar, Carli Ball-Joints, Dynatrac FreeSpin Hubs, Snorkel, RCV Axles, EBC Pads & Rotors, Aluminess Front Bumper, BIG Pul-Pal, 60" Extreme Hi-lift Jack, and more riggin' equipment, Carli Long Travel Air Bags, Bilstein 7100 Shocks - Carli Valving, Carli Control Arms, Thuren 3" SoftRide Springs, Thuren Rear Shackles, MagnaFlow Muffler, Crown Stainless Brake Lines, MORE STUFF COMIN'.
Russ NRA Benefactor Member
Longbomber
Re: Diff Temp video
Post by Longbomber » Sun Oct 07, 2018 12:16 am
I think you will see banks come out with a new cover, extra capacity and finned but with a windage tray inside to keep the oil flow directed along the ring gear.
Not much doubt that a finned cover reduces temps, but the flow of the oil could be much smoother.
Re: Diff Temp video
Post by TwinStick » Sun Oct 07, 2018 12:49 am
First off, I think we all know that soon after, he will offer his solution to this age old issue.
Diff temp does seem to be more of an issue these days, because of the electronic lockers (and the plastic parts used in them that are exposed to the hot fluid) that are available these days, not just in Power Wagons either.
Second, I do enjoy his vids, but honestly, you still can't see how much oil is or is not being slung onto the pinion gear or its bearings. I would sure like someone to explain why there have been so many "pinion bearing failures due to lack of lubrication" if the factory fill level and diff cover is the "better/best way to go", because i am at a loss for any other explanation.
My rear locker issue was with the stock cover. If I would have had my Mag-Hytec on, no doubt that they would have blamed me/it & void the warranty.
Re: Diff Temp video
Post by TwinStick » Sun Oct 07, 2018 12:51 am
Based on the videos so far, it seems that the only way to go would be an actual diff oil cooler with hoses & a electric pump.
And, doing that, in and of itself, presents another whole host of issues specifically for us Power Wagon owners.
1) If that pump fails, your f***ed, it runs every time the truck runs.
2) If the hoses get snagged on anything, your f***ed.
3) Where to mount if spare tire is in it's stock location ?
4) How do all those 90 degree bends in hose fittings affect oil flow ?
5) How much more oil do you need in the diff to keep the oil at the proper level while driving it down the road ?
6) Can the pump run dry with no issues ?---Like when slowly going down a long steep hill off-road ?
Re: Diff Temp video
Post by KevinABQ » Wed Oct 10, 2018 10:03 pm
You could drive the pump off the ring gear. Not sure that is a good idea. but it's right there. The issue that a damaged hose/radiator empties the diff is a problem. But you can use SS piping vs hoses and can shield anything with careful design and enough metal. Whether it makes any sense to go to that effort is another question.
Re: Diff Temp video
Post by DamageWagon » Wed Oct 10, 2018 10:31 pm
I love these problems. The problem isn’t the problem, it’s the lack of a solution to a problem that doesn’t exist.
So now we can all mind fuck a solution until we give up and agree there isn’t a problem that needs solving. But Gale told us there wasn’t a solution... so we had to mind fuck it to find a solution to the lack of a problem.
lol
Re: Diff Temp video
Post by olyelr » Wed Oct 10, 2018 11:09 pm
Bahahahahaha.
Re: Diff Temp video
Post by Low_Sky » Thu Oct 11, 2018 12:04 am
Looking for a diff oil cooler bypass for my 2015 PW, if anybody makes one.
Re: Diff Temp video
Post by DamageWagon » Thu Oct 11, 2018 12:08 am
Low_Sky wrote:Looking for a diff oil cooler bypass for my 2015 PW, if anybody makes one.
It’s right on the diff cover. Takes a 3/8” square drive.
Re: Diff Temp video
Post by TwinStick » Sun Oct 14, 2018 3:57 pm
Maybe after this series, he will come out with some video's that say low gearing is just a waste of money too ?
https://www.youtube.com/watch?v=WrRBbh6-eGU
https://www.youtube.com/watch?v=kYWyJoV2o6U
