2015 Power Wagon locker bypass
Plug-N-Play Locker Bypass Kits
Moderator: myoung84
spete700
Post by spete700 » Wed Sep 05, 2018 5:11 pm
Is there anyone who still sales locker bypass for a 2015 Power Wagon? Please let me know. Thanks
Re: 2015 Power Wagon locker bypass
Post by DamageWagon » Wed Sep 05, 2018 10:09 pm
Post by Bill2014 » Thu Sep 06, 2018 7:43 am
Read the details about this item carefully before you purchase... :wink:
You get the throttle and shift mappings of 4-Lo whenever it is active!
Locker Bypass
Post by Retired BLM Rig » Thu Sep 06, 2018 10:21 am
Not to mention the fact that it doesn't play well with the CAD front axle. It works but will BANG if you're moving when you flip the switch.
BoldAdventure
Post by BoldAdventure » Thu Sep 06, 2018 11:01 am
Not much more to add to the above to responses. Don't waste your money on that, you can easily hard-wire your lockers.
I did a video on it and it's saved permanently on my Instagram profile under PW Locker ByPass in the stories: https://www.instagram.com/boldadventure/
spete700
Post by spete700 » Thu Sep 06, 2018 12:31 pm
Thanks for everyone's replys!!!!! I am really looking forward to getting my Power Wagon up to shape so my family and I can enjoy some off road adventures!!!!! Thanks again to everyone!!!!
Post by RustyPW » Thu Sep 06, 2018 4:31 pm
My 3G bypass is like this. No big deal.
Russ NRA Benefactor Member
Post by RustyPW » Thu Sep 06, 2018 4:37 pm
When you shift in 4Hi or 4Lo. The CAD engages? Right? When using the bypass. The computer thinks you shifted into 4Lo. But you are still in either 2Hi or 4Hi. So why the bang? I don't see it.
Post by olyelr » Thu Sep 06, 2018 4:45 pm
No idea. But it personally happened to me once with this kind of setup. Happened to my wife too when I wasn't with her. And actually, now that I think about it, she wasnt even in 4 wheel drive, but she activated the setup to think the truck was in 4-lo. It was loud enough she though she broke the truck hahahaha.
Post by olyelr » Thu Sep 06, 2018 4:46 pm
Well it sucks in the 4.5 gens if you ask me!
Post by olyelr » Thu Sep 06, 2018 4:47 pm
But it says I need to sign up :(
Post by RustyPW » Thu Sep 06, 2018 4:48 pm
Does it bang when shifting the transfer case from 2Hi to 4Hi? Or just when using a bypass?
Post by olyelr » Thu Sep 06, 2018 4:51 pm
It was intermittent. I honestly cant remember exactly when it did it. Never did figure out what was going on.
I just know I heard/felt it once, and my wife did as well when she accidentally activated the setup (had it on my homelink button, and she hit the wrong garage door opener button leaving - she had no idea I even had the setup on the truck). But she wasnt even in 4wd, I know that.
Post by Low_Sky » Thu Sep 06, 2018 6:54 pm
I wonder if telling the truck it’s in 4LO (bypassing) when in 2HI is forcing the CAD to lock up faster/harder/differently than shifting into 4HI or 4LO normally.
Post by olyelr » Thu Sep 06, 2018 7:20 pm
It is possible. I never did put much thought into figuring it out because I disliked the higher RPM and mapping so much that I knew I was gonna get rid of the setup. I am not sure it was coming from the CAD or the tcase, but I suspected the CAD.
