Removal of rear sway bar?
kgries
Post by kgries » Sun Sep 02, 2018 2:27 am
I was thinking about taking off my rear sway bar. Does anyone notice any loss in control or increased body roll with highway driving?
I want purple cranium diff covers and I want to get a thuren kit but I don’t want the sway bar to rub. It would save me a few hundred on the links as well
Re: Removal of rear sway bar?
Post by Reloaderguy » Sun Sep 02, 2018 11:18 am
If you always have the OE front sway bar connected you'll probably be fine. However, the 14+ trucks are sensitive to weight because of how far inboard the rear springs are. I'd probably just make a spacer for the rear sway bar, the diesel guys running the larger capacity diff covers go through the same problem.
Post by TankerZak » Sun Sep 02, 2018 11:44 am
You can just flip the rear sway bar. I'm going to remove mine in Moab and when I put it back on I'll flip it.
Post by DamageWagon » Sun Sep 02, 2018 7:18 pm
I am imminently working on a solution to run the Thuren swaybar links with rear diff covers. If things work right I’ll have a cheap solution. Prototypes are already in my hands. You can run without the rear swaybar but really the tears of these trucks ought to have one on, with how onboard the coil springs sit.
Post by Low_Sky » Sun Sep 02, 2018 9:28 pm
After installing my 2.5” King Thuren kit, I test drove without the rear sway bar. There was a noticeable small amplitude sway that I think was within the front sway bar dead spot, and not great enough that the shocks could damp it fast enough for my liking. I made DIY spacers, got longer bolts, put the sway bar back in. Small amplitude swaying went away.
Sounds like Damagewagon has the commercial solution to this problem coming along shortly.
kgries
Post by kgries » Mon Sep 03, 2018 1:26 am
well that's good to hear!
Post by PWJouster » Tue Sep 04, 2018 9:34 am
need the spacers. im on board so let us know.
my half cranium is taking a beating on the surface. honestly, the sticker has worn with slight abrasion to the spider metals plate.
i have made some loud contact, but the bar is not damaged. it is only a sound annoyance at this point.
17 Method NV-Toyo RT 35
SPOD
Post by DamageWagon » Tue Sep 04, 2018 2:57 pm
I’m testing it out tomorrow
Post by TankerZak » Tue Sep 04, 2018 8:27 pm
You must be making a lot more contact than I am... I can't tell if I'm hitting or not. But it's really really close and I'm sure it would if I drooped it out.
DamagedWagon, I'll take a set of your first production run spacers. :)
Post by Low_Sky » Wed Sep 05, 2018 12:28 am
TankerZak wrote:You must be making a lot more contact than I am... I can't tell if I'm hitting or not. But it's really really close and I'm sure it would if I drooped it out.
The swaybar makes contact w/the half spider in compression. If you’re looking with the suspension drooped you’ll never see it ;)
Post by TankerZak » Wed Sep 05, 2018 12:37 am
Either way, I haven't heard it. But I'm also taller than most in the rear with an additonal 1 inch spacer.
BoldAdventure
Post by BoldAdventure » Wed Sep 05, 2018 10:57 am
What for DamageWagon's spacers. The rub is just going to rub the paint/powder coat off. It won't damage anything. Mine has been rubbing for some time.
If you tow, or have anything like a RTT in the back, you want your sway bar connected. If you guys are running Thuren's kit, when you disconnect the rear sway bar, you'll get a TON of flex out of the whole system. See the pictures attached:
Depending on what I'm doing, and if I have the tent or not, depends on when I have the sway bar connected. I prefer it for towing, tent and highway. Offroad without the tent, I like to disconnect it.
Post by TankerZak » Wed Sep 05, 2018 11:11 am
Someone needs to come up with a manual QD system.
Post by adeluca73 » Sat Sep 08, 2018 12:52 am
I flipped mine—still really close. I think my little white spyder is squished, probably need to shit can the whole thing now :wink:
Post by adeluca73 » Sat Sep 08, 2018 12:57 am
John—your PW is coming along nicely, great looking rig you got there!!
kgries
Post by kgries » Mon Sep 24, 2018 12:30 am
well i found out DOR has spacers so i ordered those.
does anyone know any quick disconnect links that are long enough to be used with the thuren shocks and springs?
BoldAdventure
Post by BoldAdventure » Mon Sep 24, 2018 10:28 am
There are none you can buy. I looked. But there are a LOT of DIY examples online. Jeepers have been building these for years. It's fairly inexpensive.
Usually, for me, the only time I remove mine is when I'm in Moab, and I usually happen to be in Moab for a week or so, and I end up just removing the whole bar. For a lot, and I mean a lot of stuff, I don't see the benefit. It's not until you're doing some technical crawling that it's an added boost, IMO.
kgries
Post by kgries » Mon Sep 24, 2018 3:10 pm
gotcha alright ill scrap that idea hahah
Easttnrhino
Post by Easttnrhino » Sun Nov 25, 2018 8:32 pm
Pulled mine off 11/2 ago I do tow a some not much, haul wood but do not try to drive it like I ride my harley.I think truck rides better but take link off one side and drive for a few days and try we all have a little different taste and ideas.
Enjoying beautiful east TN
