I called Hutchinson last week, they make two offsets for 8on6.5; 10mm and -10mm. Unfortunately if those two sizes won't work that's all Hutchinson offers. I really wanted a set because I hate dealing with water and mud in the wheel but I needed something different.RustyPW wrote: ↑Fri Aug 31, 2018 12:29 amI was just wondering about the doubles. The more info, the better.DamageWagon wrote: ↑Thu Aug 30, 2018 11:10 pmAll that said, if you want a double beadlock, both Hutchinson and TR make them, I’m not sure who else. Hutchinson makes the split-center style. TR makes both split-center and they make an insert that goes with their standard ring-style. Hutchinson is MUCH cheaper for a double beadlock!
I looked at all of the usual suspects and ended up back at TR because they have the best reputation/reviews at a decent price. Also, Damage Wagon was willing to set up a dealer account so I could order a set of wheels. Give him a call, he's easy to work with and will treat you right. There isn't much money in TR wheels which is why you see them all priced the same. DW has some good things in the works!
