Tradesman/power wagon vs power wagon snowplow prep
ssiannino
Post by ssiannino » Tue Aug 14, 2018 9:18 pm
Hi guys so I ordered a 2018 power wagon and you can’t get the plow prep package with it which is a 220a alternator and skid plate. I ordered it with the dual alternator and we know it comes with skid plates. So if you order a tradesman with the power wagon suspension you can get the plow prep package. Anyone know why
Re: Tradesman/power wagon vs power wagon snowplow prep
Post by Reloaderguy » Tue Aug 14, 2018 9:43 pm
Because the snowplow prep group includes heavier front springs and the PW comes with linear rate 2" lift coils.
Post by olyelr » Tue Aug 14, 2018 10:40 pm
Yes. Actually I believe they (RAM) advise against putting a plow on a power wagon. Just like putting a camper in the bed.
ssiannino
Post by ssiannino » Wed Aug 15, 2018 5:50 am
So doesn’t the power wagon package on the tradesman include the same suspension that’s on the power wagon.
That’s how they are advertising it from Ram I haven’t found anything to say otherwise.
13powerwagon
Post by 13powerwagon » Wed Aug 15, 2018 7:48 am
Yes, they have the same suspension.
2013 tradesman
Thuren 2” coils, track bar, control arms, 2.5 Kings and axle truss. Carli ball joints, DOR steering brace, AEV salta wheels, 35” nitto ridge grapplers, white knuckle sliders, purple cranium dif covers.
ssiannino
Post by ssiannino » Wed Aug 15, 2018 8:42 am
So there is no reason that I could think of looks like I am calling Ram to find out
Post by Reloaderguy » Wed Aug 15, 2018 9:04 am
The Power Wagon comes lifted. You can't have a lift and heavy duty plow springs.
13powerwagon
Post by 13powerwagon » Wed Aug 15, 2018 9:36 am
There are people on this forum that have added snow plows to their trucks( just do a search), you don’t need the snow plow package to make it work. That being said, you can’t have the power wagon package and the snow plow package, try building a regular powerwagon, snow plow prep is not an option there either.
Edit. So I understand what you are asking now, when you build the tradesman powerwagon it DOES allow you to select the snow plow prep. Not sure why, calling ram is prob your best bet.
2013 tradesman
Post by Low_Sky » Wed Aug 15, 2018 1:34 pm
You may find this shocking, but Ram routinely has mistakes on their website, including the build&price tool.
ssiannino
Post by ssiannino » Wed Aug 15, 2018 1:36 pm
If you build a tradesman and add the power wagon package you can add the snow plow prep package also.
Just did it on the ram truck website. That’s why I am asking about this, ram states that the suspension is the same
Post by Bill2014 » Wed Aug 15, 2018 1:41 pm
I don't think the dealer interface will allow the combination. Hence, it can't be ordered :secret:
But you can certainly get a price on that imaginary configuration. :popcorn:
ssiannino
Post by ssiannino » Wed Aug 15, 2018 2:09 pm
:doh:
Post by olyelr » Wed Aug 15, 2018 2:46 pm
But you can certainly get an imaginary price on that imaginary configuration. :popcorn:
Fixed it for you.
DirtyOffroad
Post by DirtyOffroad » Fri Aug 17, 2018 10:16 am
Just checked my dealer interface. Snow Chief Group and Snow Plow Prep Group are both Tradesman options however are not allowed with the PowerWagon Package. PowerWagon comes with everything in both so they are unavailable. Does not show any difference for suspension on my screen.
2018 Ram 2500 Powerwagon
1.5 Thuren - Front
Thuren Rear Track Bar
LED Headlights and Fog
Post by RustyPW » Fri Aug 17, 2018 10:26 pm
The PW has taller, softer springs. The PW sits about 1.5" to 2" taller the a standard 2500. For the 3G's There was 27 different spring combinations for the PW depending on which options was chosen.
Post by TwinStick » Thu Aug 23, 2018 9:06 pm
Mfg says: snow plow pkg no worky with PW due to softer springs. People have done it though with no issues......unless you have a dealer that is just looking for a reason to void your warranty, like mine.
They tried to void my lifetime powertrain warranty because of all the top shelf (at that time) aftermarket parts i put in the front end. I laughed at them & said first of all, i did that because of the shit factory parts they used, second of all, so i would have some long term reliability, 3rd of all, they have NOTHING to do with the powertrain. I also went through that again when they had to replace my rear locker mechanism. Owner finally said it would be covered under the lifetime powertrain warranty, but if i had a lift or bigger tires on it, they would have voided it for sure & used that as the excuse not to cover it. As it was, I had to threaten to get Channel 4 "Call 4 Action" to show up if they wouldn't cover it. :angry:
