How many of you are overweight?
Re: How many of you are overweight?
Post by Bill2014 » Tue Jul 17, 2018 10:22 am
Probably should have used the CTD for this recent trip because it ended out being an overload. But the Power Wagon managed to do the job. :cheers:
Front Axle: 4520 lb
Rear Axle: 5400 lb
Trailer Axle: 15980 lb
Gross: 25900 lb
Locker Bypass
Post by olyelr » Tue Jul 17, 2018 3:01 pm
Front Axle: 4520 lb
Rear Axle: 5400 lb
Gross: 25900 lb
Quick question. Seeing how you seem to often haul heavy loads, and you have a cummins, why do you even use the power wagon for towing? I mean, it must feel like a complete turd after using a diesel, no?
RPS1030
Post by RPS1030 » Tue Jul 17, 2018 6:03 pm
What's your setup on these loads as well? Bumper or GN?
2016 Power Wagon Tradesman-White-37" Toyo RTs/Inyati Bedliner/Baja Designs Squadron Sports/CVT RTT/Metalline Fab Bed Rack
FToy #43
Post by Bill2014 » Tue Jul 17, 2018 11:06 pm
Front Axle: 4520 lb
Rear Axle: 5400 lb
Gross: 25900 lb
Actually, I don't find as much difference as you might think. The Power Wagon (410 hp) has 60 hp over my CTD (350 hp) and the CTD is still 500 pounds heavier. From a dead stop, the Power Wagon will get to 55 mph faster than the CTD with the same heavy load. The Power Wagon does make a lot of engine noise if you are trying to keep up with stop and go traffic and have the engine racing above 4000 rpm :wink:
Hauling stuff off road, the Power Wagon is always better. The Duratracs get better traction than the CTD OEM tires. Diesel torque is great - but only if you have traction.
Locker Bypass
Post by Bill2014 » Tue Jul 17, 2018 11:20 pm
OEM 2.5" receiver..
16000 pounds max Gross Trailer Weight (3000 pounds max tongue weight) Titan by Reese
A goose neck would be sweet - but it's nice to have a trailer that can be used by any heavy duty SUV or non-truck
Locker Bypass
Post by Bill2014 » Thu Jul 26, 2018 1:54 pm
Had to use a new mine location - asked for 5 tons and they dropped 7 tons in my trailer for one of the loads. The poor Power Wagon. :o
Locker Bypass
Post by Bill2014 » Mon Jul 30, 2018 10:25 am
14'x7' dump trailer
Locker Bypass
