37x12.5 on AEV Saltas – metal trimming or liner only (2018)?
JamesWyatt
Re: 37x12.5 on AEV Saltas – metal trimming or liner only (2018)?
Post by JamesWyatt » Sat Jul 14, 2018 1:36 pm
Thanks to everyone for the advice and all the help with this. Here's how it ended up! I'll post more in the official Power Wagon Picture Thread.
Post by TankerZak » Sat Jul 14, 2018 4:13 pm
Shaved Ice wrote:
Sat Jul 14, 2018 12:24 pm
JamesWyatt wrote:
Fri Jul 13, 2018 10:42 am
Exactly what I'm hoping for! I went with the AEV wheel because they state it will allow fitment of 37s, and they didn't mention cutting being required...
I remember reading it had to be a 37” BFG KO2 because they run small. Toyos run true to size or even bigger. This is probably where the discrepancies are coming from.
I've never seen a true to size tire.. hell i think my 37s are actually 35.75 when run at a reasonable pressure. They are 36.5 before you put the truck on em.
Post by DamageWagon » Sat Jul 14, 2018 5:17 pm
No tire stays at it’s manufactured diameter when you set 2,000lbs on it
EasyDoesIt
Post by EasyDoesIt » Sat Jul 14, 2018 5:33 pm
Great photo man, the truck looks so clean.
JamesWyatt
Post by JamesWyatt » Sat Jul 14, 2018 6:44 pm
BFG is notorious for being smaller than other brands in the same sizes. I think the consensus is Toyos run “closer to true size”, but not “true”.
JamesWyatt
Post by JamesWyatt » Sat Jul 14, 2018 6:46 pm
Thanks, hopefully it won’t be clean for long :D
Easttnrhino
Post by Easttnrhino » Wed Aug 01, 2018 5:30 am
Good looking truck jameswyatt.i know this has most likely been answered and or bet to death, but how much more offset do the aev rim have than stock . Thanks
Enjoying beautiful east TN
Post by Low_Sky » Wed Aug 01, 2018 1:28 pm
I've seen conflicting numbers, but I think the current PW rims are +44, or thereabouts. The AEV Ram wheels are +27. So about 17mm less offset than stock.
Post by OffroadTreks » Wed Aug 01, 2018 2:30 pm
Thuren suggests the Power Wagon wheel is from +42mm to +57mm (odd to list a range, but he does) - I bet the AEV offset is better than a lot of the guys who go with +18mm since they stick out less.
Rodeoflyer
Post by Rodeoflyer » Wed Aug 01, 2018 10:07 pm
Oh crazy, subforums... I though the AEV's were +18. I'm looking at CJC's custom (cheap) raceline for dodge which are +20 for 37's.
Post by TankerZak » Sat Aug 11, 2018 9:45 am
At +18 your right ontop of the pinch seem. At +20 i didn't have to trim but i get some very very very slight rubbing (like radio off to hear it) at hard lock. I think it's still the sway bar. AEVs are +27 so you'll probably get some light rubbing in the same places. Best for no rub chance is probably +18 and a willingness to modify the pinch seem a hair. (And a 12.5 wide tire)
Post by TwinStick » Sat Sep 01, 2018 10:57 pm
Original Cooper STT tread pattern https://www.summitracing.com/parts/coo- ... gJl4fD_BwE
Toyo Open Country M/T trad pattern https://www.walmart.com/ip/Toyo-Open-Co ... 3=&veh=sem
Very similar. :D
Traded to 2019 ZR2, Red.
