idtanker's Build - 2013 Power Wagon - "Bertha"
idtanker
Post by idtanker » Mon Jul 02, 2018 1:56 am
2013 Power Wagon DG-540199
4.56 Gear ratio, Volant CAI, Mastercraft Courser MXT 35×12.5×17s on $500 American Racing something or others, Pedal Commander, JHD Lighting mirror mod, Grant Stott USB mod, Outlaw Products Zombieflauge Horde canvas seat covers, Onetigris seatback Molle organizers, Heka front mounted 2 inch recievers, Warn epic winch hook, cabin air filter addition with donor cover from another Ram, Wilson cell phone signal booster,
idtanker
Re: "Bertha"...my 2013
Post by idtanker » Mon Jul 02, 2018 1:22 pm
Bought her in Sept. 2017, an Arizona truck. I hope to do some amazing things with her once the warranty runs out. Between this forum and the actual facebook pages dealing with PWs, I have learned alot, and hope to continue learning!
So far...testing the waters mods...
JHD Lighting sideview mirror mod
Added USB outlets to the back seat areas...left and right...
Volant CAI
American racing wheels with Mastercraft MXTs 35×12.5×17 tires
idtanker
Post by idtanker » Mon Jul 02, 2018 3:15 pm
The day I picked her up.
w2dodge
Post by w2dodge » Tue Jul 03, 2018 3:22 pm
:cash: congrats..
ghaugo
Post by ghaugo » Tue Jul 03, 2018 5:22 pm
Sweet truck. Welcome to the club! You are going to have fun. Thanks for your service. I spent my time at Ft. Carson in an M1A1 back in the day.
Aluminess Rock Sliders, Cooper STT Pro 315/70/17, ARE Z-Series Topper, FilterMag GP101 (front and rear diffs), DeeZee Tailgate Assist, Skanda Kryptec Typhoon seat covers, Husky X-act Contour Mats, Purple Cranium Diff Covers Front and Rear, Dodge Offroad Steering Brace, Volant CAI with Donaldson PowerCore Filter, Thuren Track Bar, Thuren Short Arms, All AMSOIL fluids from Code4Synthetics.com
idtanker
Post by idtanker » Wed Jul 04, 2018 3:30 am
:cash: congrats..
Thanks!...Its good to be here!
idtanker
Post by idtanker » Wed Jul 04, 2018 3:34 am
M1A1s, M1A1 heavies and M1A2s as well as A2 Bradleys and up, Deployed 2x as a Tanker and ended up in Humvees.... :wtf:
Post by coder » Thu Jul 05, 2018 7:06 pm
Welcome, congrats on the new to you Power Wagon! Does everything function properly, winch, lockers, sway-bar disconnect, etc? What are your initial impressions thus far?
idtanker
Post by idtanker » Fri Jul 06, 2018 10:41 pm
So far so good, everything seems to work as advertised, the previous owner took good care of her. It initially had 21,000 miles on it, and I have put another 12,000 since September 17.
Used the winch to pull a little 2wd patriot out of the southern Idaho mud, winch pulled it out with no issues, except having to keep rpms up. My first winching, so lesson learned.
I got her before hunting season last year, so off we go to near the Oregon border, about a 3 hour drive from Boise, and a 21ft toyhauler with my 2 quads. ( For reference, I used my 03 H2 for this run in previous years, burned half a tank for the trip, 6.0 vortec) It pulls like a champ....figure 4750lbs of trailer and add 1200lbs of quads, gear, and water...not heavy, but not bad. I come out using just under half a tank, and since ive drawn cow elk and turkey, ill be heading that way again this year. It snowed early last season, so, for fun I locked it up and used the disconnect for the swaybar to climb into a few areas I havent been before...everything worked perfectly.
All in all, I am glad my wife talked me into getting this beast, and hope to learn even more!
idtanker
Post by idtanker » Fri Jul 06, 2018 10:45 pm
Added 2 inch recievers this evening
idtanker
Post by idtanker » Tue Jul 10, 2018 8:56 pm
Added some hooks
idtanker
Post by idtanker » Tue Jul 10, 2018 8:57 pm
Added some hooks, hope to use this as a base for my removable brush/grill guard.
BoldAdventure
Post by BoldAdventure » Wed Jul 11, 2018 12:17 am
More Boise people!
Post by Bill2014 » Wed Jul 11, 2018 7:46 am
I assume you bolted the receivers to the mounting plate that the factory rings were bolted to? If so, beware, that factory mount is not as strong as you might hope. They will likely bend and deform if you use one of your hooks as a sole recovery point.
If you beefed up the factory ring mount, please share what you did. :wink:
Locker Bypass
idtanker
Post by idtanker » Wed Jul 11, 2018 4:17 pm
Thanks for the tip, no, I did not beef them up, but...now I know and have another project, besides, I dont think I want to use them as a sole recovery point, but as an additional. Appreciate the feedback!
idtanker
Post by idtanker » Wed Jul 11, 2018 4:19 pm
More Boise people!
Hell yeah!...I have found we hide out on alot of the FB pages as well...gotta love Idaho!
idtanker
Post by idtanker » Sat Jul 14, 2018 11:16 pm
Added new shackle mounts and 32 ton shackles, along with a Warn epic winch hook. Thinking of making one for the rear as well.
idtanker
Post by idtanker » Sat Jul 14, 2018 11:33 pm
mirrors.jpgUSB.jpgBought her in Sept. 2017, an Arizona truck. I hope to do some amazing things with her once the warranty runs out. Between this forum and the actual facebook pages dealing with PWs, I have learned alot, and hope to continue learning!
Volant CAI
Molle seatback covers
idtanker
Post by idtanker » Thu Jul 19, 2018 10:58 am
Goofing around at work....while the bosses are away...
Post by Low_Sky » Thu Jul 19, 2018 10:32 pm
Is there some big picture reason you did this? Looks like putting adapter adapters on your adapter to me.
Post by TankerZak » Fri Jul 20, 2018 9:05 am
Hah!!! More Tankers!! M1A1 Heavy, M1A1 AIMS, Ft Hood, Korea, and Germany.
idtanker
Post by idtanker » Fri Jul 20, 2018 4:21 pm
Rubicon belongs to a fellow Instructor, not sure his setup, but he is dying to get his pavement princess to MOAB. He and his wife are jeep fans, and he has dine all the work himself, at least I think he has. Please dont ask if he has experience in these things, im pretty sure its "oooooh look at that!"....and it ends up on the jeep.
idtanker
Post by idtanker » Fri Jul 20, 2018 4:24 pm
As for Bertha, I was just playing around...the ramp is really for boresighting the Tanks, and well, one thing led to another....
idtanker
Re:
Post by idtanker » Fri Jul 20, 2018 6:52 pm
Post by Low_Sky » Sat Jul 21, 2018 3:06 am
Never seen a steel plumb and sync ramp (we had concrete ramps at Hood), but I was asking about the frame horn to hitch receiver to hitch adapter to shackle setup.
