Mufflex Magnaflow bolt on and resonator removal
PWJouster
Post by PWJouster » Mon Jun 11, 2018 4:29 pm
looking to install the mufflex magnaflow kit.
then chop off that rear resonator with a turn down tip next to the rear wheel.
does anyone have this exact setup, and what exhaust tip did you utilize? looking to find the right exhaust tip that can clamp down and not be welded.
it seems everyone has trustworthy welders to get their tips on
2018 Powerwagon
Thuren King 3.0-S3 & 2.5-S2 with King Stab, TBs, Boogies and
Dodge-Off-Road Steering Brace
Method NV 17s
Toyo RT 35x12.5/17
Purple Cranium F&R
S&B Intake
Exhaust
Easttnrhino
Re: Mufflex Magnaflow bolt on and resonator removal
Post by Easttnrhino » Tue Jun 12, 2018 8:12 pm
I went the local AutoZone and measured and they let me try them sorry do not remember part number
2017 wagon in beautiful east tn
Post by DamageWagon » Tue Jun 12, 2018 8:21 pm
I think the Y-Pipe delete provides the best sound on these Hemis
PWJouster
Post by PWJouster » Wed Jun 13, 2018 11:03 am
y pipe delete to a true duel exit?
2018 Powerwagon
Method NV 17s
Toyo RT 35x12.5/17
Purple Cranium F&R
S&B Intake
Exhaust
Post by Reloaderguy » Wed Jun 13, 2018 11:37 am
I'm not sure what he means but the OE y pipe is probably the largest restriction in the exhaust system. Duals aren't needed if you replace the Y pipe and run 3.5" pipe back.
Post by DamageWagon » Wed Jun 13, 2018 11:49 am
Yep, very cheap too. Just cut off the y-pipe and pull all the shit off behind it. Ta-daaaa!
I suppose open headers sound better but the neighborhood doesn’t like them
Post by adeluca73 » Fri Jun 15, 2018 4:46 pm
Yes..I did that exact thing. Mufflex + chop the resonator & dump exhaust after the axle. Used standard 90deg turn
