Tires Fitment
Tires Fitment
Might run into an issue with tire fitment, though very slightly. My understanding is that there is a pinch weld on the rear side of the front wheel well. What is the proper fix for it? I know on my jeeps I always beat them flat and painted them
2018 Ram 2500 Powerwagon
1.5 Thuren - Front
Thuren Rear Track Bar
LED Headlights and Fog
1.5 Thuren - Front
Re: Tires Fitment
Dremel & malletDirtyOffroad wrote: ↑Tue Apr 17, 2018 8:51 amMight run into an issue with tire fitment, though very slightly. My understanding is that there is a pinch weld on the rear side of the front wheel well. What is the proper fix for it? I know on my jeeps I always beat them flat and painted them
Re: Tires Fitment
Beat flat and paint worked for me. I did a couple relief cuts on the pinch weld so it folded over perfectly flat and rounded the end of the pinch weld that was still standing with a grinder.
Re: Tires Fitment
I used an air powered body saw to cut pinch weld area back to the plug weld portion and used chassis saver paint to make certain it didn't rust. Used a heat gun to reform (and partially mangle due to too much heat and plastic sticking to wood I used to push it/mold it) plastic wheel liners.
Re: Tires Fitment
Is this on a 4th gen? Any pics of the process or outcome?
Re: Tires Fitment
Yes, my 15 cough cough some guys 15 cough cough. I prefer to hide the evidence of stupidity/newness with a heat gun.
