Checking In
fbenross
Checking In
Post by fbenross » Thu Mar 08, 2018 1:25 pm
I had better check in before some of the old timers think I’m a pile of bones in the Owyhee Desert. I just spent my first year retired and went over 39k miles on my PW/RV. It is a Dinosaur and will be 12 in April. All but 2000 of those miles with a Ton of popup camper and gear on the back. I took the camper off for this winter and it’s like having a new truck. The tires are chirpy when shifting that 6 spd, and it rides like a Buckboard. The wife was following me the other day and later she said “you have the biggest truck on the road” so I took her out to dinner…out smarted by her again!
I’m surprised I still have the stock F brakes, but it is pulling to the right slightly under braking now. All is still working well with the stock 06…lockers, sway bar, and winch still working fine. I am on my 3rd P.S. pump, both changed in the field by this old man. I finally got around to doing the recall on the air bags and clutch lockout switch/spring, and after 12 years outside by the ocean, there is no serious rust yet. No Snorkel has been needed yet, but I have dared to get the Smart Bar electrics wet twice :doh: …I still love banging the gears in the old girl, and I did notice the guy checking it out in the Safeway parking lot. She is one good looking, scratched up girl but every scratch was worth it.
The Camper will be going back on this May for a D.V. trip, retirement has been a whirlwind, I find myself spending less time on line and more time doing home, yard, and vehicle projects. I feel a bit left behind on the forum with an old 3G, but there is a price to pay for having the best Gen PW. I Hope all are well. Ben
Re: Checking In
Post by olyelr » Thu Mar 08, 2018 3:33 pm
Nice to see ya around again. Enjoy retirement!
Re: Checking In
Post by Colibri » Thu Mar 08, 2018 3:39 pm
Glad you’re doing well! Don’t worry, there’s still some of us third gen guys around. Good to see you back around these parts sir
Ducky's Dad
Re: Checking In
Post by Ducky's Dad » Thu Mar 08, 2018 9:49 pm
Well, it's about time. My '05 is still the best truck I have ever owned, and I plan to keep it for as long as I am able to drive. Also retired, and too damned busy to enjoy life.
Re: Checking In
Post by RustyPW » Thu Mar 08, 2018 11:05 pm
Glad to hear from you Ben. Thought maybe you got lost out in the desert. Yeah, retirement has been something else. :lol:
3G's forever! :rockon:
Mods to the PW; Nerffed Mopar RockRails, Wheel Well Liners, Bushwacker Pocket Fender Flairs, Garvmin dezl 560LMT GPS, Power Wagon Winch Kit, Line X Ultra Bed Liner, PIAA Headlight Bulbs, PIAA 580 Driving Lights (135 watt), PIAA 520 Fog Lights (135 watt), PIAA 520 ATP Off-Road Lights (135 watt), Locker Bypass, Modifed Rockcrusher Diff Covers, Mopar Utility Bed Rails and Tool Box, Warn Winch Wireless Remote Control, "el-cheapo" Inclinometer, Airaid CAI, Winch TPS Bypass, 35" Toyo's, Mopar Spare Tire Lock, 'T' Steering Linkage, Modifed PSC Steering Brace, P3 Brake Controller, Modifed Fusion "mall crawler" rear bumper , PIAA 1500 Back-Up Lights, 1Ton HEMI Tranny Cooler, Leer 100XR Bed Cap, Factory Tow Mirrors, CenterLine Rims 17x9-5.25 BS, Mag-Hytec Tranny Pan, AutoMeter Gauges, PSC Extreme Hydro Assist Steering, Carli G2 Track Bar, Carli Ball-Joints, Dynatrac FreeSpin Hubs, Snorkel, RCV Axles, EBC Pads & Rotors, Aluminess Front Bumper, BIG Pul-Pal, 60" Extreme Hi-lift Jack, and more riggin' equipment, Carli Long Travel Air Bags, Bilstein 7100 Shocks - Carli Valving, Carli Control Arms, Thuren 3" SoftRide Springs, Thuren Rear Shackles, MagnaFlow Muffler, Crown Stainless Brake Lines, MORE STUFF COMIN'.
Russ NRA Benefactor Member
w2dodge
Re: Checking In
Post by w2dodge » Fri Mar 09, 2018 4:12 am
:cheers: enjoy ..
Re: Checking In
Post by Mule007 » Fri Mar 09, 2018 7:54 am
:rockon: :rockon: Love ours! Keep enjoying retirement !
2005 Mineral Gray PW; Alloquin 3" rock rails w/low profile steps; 2.5" Skyjacker suspension lift kit; Toyo Open Country AT II Extreme-35 x 12.5 x 17 10 ply's; McQuay-Norris Extreme ball joints; T-steering upgrade w/Bilstein 5100 steering damper; Bilstein 5100 Mono tube nitrogen gas shocks; Denso 180 amp alternator, Interstate Mega-tron 850 CCA HD battery; MoPar rear wheel well liners, black accent fender flares, remote start, and Ravelco Anti theft device; Hopkins Trailer Mate trailer brake controller; Hemi 1 ton transmission cooler; Uniden Bearcat Pro 68XL CB radio; Linex Platinum black armor truck bed & lower rock panel armor coating; Matching Range Rider cab high fiberglass canopy; 2" Linex (matches Alloquin) round brush guard light bar w/ 4- KC HiLites Rally 400 Series 4" Halogen Driving/off road lights; Dyna-flow cat back dual exhaust; GT Platinum srt-10 A-pillar pod mount programmable performance chip, monitor, tuner; an S&B CAI.
Re: Checking In
Post by TwinStick » Fri Mar 09, 2018 2:31 pm
Glad to hear from you again Ben ! :patriot: Nice to see you out using your truck. Don't worry, there is still a few of us 3rd Gen guys left on here, & I am still loving banging the gears on my old girl as well. 39k in 1 year ??? :notworthy: Take care.
Re: Checking In
Post by DamageWagon » Sat Mar 10, 2018 9:57 pm
Glad to hear from you man! Sounds like you’re enjoying life! I really enjoy having you 3rd gen guys around, you have real problems and real solutions and enjoy your rigs more with all the work you have to put into them haha
NovA ProspekT
Re: Checking In
Post by NovA ProspekT » Sat Mar 17, 2018 9:42 pm
Glad to see you still around! I haven't been on much recently myself...
Not to hijack, but what happened to the front page of the website(not the forum)?
[---- 2007 Dodge Power Wagon ----]
[My build - My Flickr]
Though my soul may set in darkness, it will rise in perfect light;
I have loved the stars too fondly, to be fearful of the night
“The death-knell of the republic had rung as soon as the active power became lodged in the hands of those who sought, not to do justice to all citizens, rich and poor alike, but to stand for one special class and for its interests as opposed to the interests of others.” - Theodore Roosevelt
Re: Checking In
Post by Retired BLM Rig » Sun Mar 18, 2018 12:49 am
It went up in a ball of flames. Read post #15.
