Few upgrades to the Gator
TrueCowboy426
Post by TrueCowboy426 » Sat Jan 27, 2018 10:46 am
Had a couple days to play in the shop so decided to do some upgrades to my Gator. Put on a 4000lbs warn and added a 2" receiver (handy for pushing wagons into tight spaces or using for recovery. Also decided to try and build a tube bumper for it. Not entirely happy but will do the job. I made all my own mounts for this stuff as these item from Deere cost a small fortune!
Re: Few upgrades to the Gator
Post by olyelr » Sat Jan 27, 2018 1:59 pm
Great job! :cheers:
Yea, if it says JD on it, its twice as much as it should be !
TommyG
Post by TommyG » Sat Jan 27, 2018 6:42 pm
Bumper looks great.
Post by TwinStick » Sat Jan 27, 2018 6:58 pm
:rockon:
