snorkel guys .. need your input
I live in dusty AZ and the aev raised intake with precleaner
My question is did it cause a lot of wind noise on highways? How much does it block your view?
Anybody regret doing it? Its a one way street and im keeping the truck long term, but want to make sure i factor everything in.
Thanks
Thanks
Auxbeam 42 curved lightbar
RANCHO 9000XL suspension
EMF ball joints
EMF ball joints
Re: snorkel guys .. need your input
I have the Ram Air, and surprisingly, ZERO noise. Like it's not even there. It also does not block your view unless you lean forward and look to your right. It might, in that case, hide a pedestrian. It is a little noticeable, but more like a black blob that wasn't there before. But not view blocking in any way. It fits that pillar very tightly. But otherwise, AEV designed a perfect product.
I have one on a 3G. The wind noise is a little more. Looking in that direction. The pillar looks thicker. Scraping snow and ice off the windshield takes a little more time. Because you have to pull it to the side, then down.
Perfect would have moved the air filter so we could mount a second battery in the same location as the diesel trucks.
That would be awesome... i have dual alts and dual batts would be nice...Reloaderguy wrote: ↑Sun Jan 07, 2018 7:34 pm
It really wouldnt be that difficult but probably just too small a market...
To the other replies, thanks... thats the info im looking for
Any mpg decrease?
EMF ball joints
EMF ball joints
My mileage stayed about the same.
Yeah, again zero impact. No improvement, not decrease. Mostly looks. I extended my breathers and taped it up.
Thanks.. i was hoping for zero impact.. so looks like i may end up with one eventually...
The dust here can get crazy if youre not the lead vehicle
EMF ball joints
EMF ball joints
Understandable... but is it really any cleaner a few feet higher?
Probably not that much although it does make a small impact...
Im more interested in the prefilter....
the cyclonic precleaner appears to work really well.. there are videos on youtube showing how much dust that thing can spin out
EMF ball joints
EMF ball joints
As opposed to the intake in the inner fender? I have to think the snorkel air path would have less dirt in it assuming you aren't driving through a Haboob.
I actually have noticed I have to clean the filterless, especially since I made sure it's all sealed.
I would imagine if you keep the stock unit and use the pre-filter it should stay cleaner. Interesting observation, you can hear the intake sucking from outside the vehicle if you stand by it when it's idle.
If you stand next to their lift you can hear it sucking too.MikeKey wrote: ↑Mon Jan 08, 2018 9:07 amI actually have noticed I have to clean the filterless, especially since I made sure it's all sealed.
Reloaderguy wrote: ↑Mon Jan 08, 2018 9:18 amIf you stand next to their lift you can hear it sucking too.MikeKey wrote: ↑Mon Jan 08, 2018 9:07 amI actually have noticed I have to clean the filterless, especially since I made sure it's all sealed.
that’s fucking hilarious, actual tears I laughed so hard
BAAAHAHAHAHAHHHAAHAAAHHAH
Thought that I was going to split my ice tea out.
This older thread on the AEV Raised Air Intake might help: http://forum.powerwagonregistry.org/vie ... air+intake
Thanks... answers most of my questions04Ram2500Hemi wrote: ↑Fri Jan 12, 2018 5:45 pmThis older thread on the AEV Raised Air Intake might help: http://forum.powerwagonregistry.org/vie ... air+intake
EMF ball joints
EMF ball joints
