Logic Check -- Airbags
ramv
Post by ramv » Mon Nov 13, 2017 10:23 pm
Ideally I will get to a 1.5" lift Thuren/King 2.5 kit. Since I bought the truck to be a truck, I would need airbags to go with the Thuren springs.
I have a good Viair compressor for tires, but was thinking a std duty remote controlled compressor to a) keep the air bags above 5 psi and b) encourage me to actually use them correctly. (I had front air bags on my Chevy, the slime compressor from Walmart was plenty to inflate, but my laziness limited the amount of times I actually adjusted, I mainly kept them at ~ 40 psi for the lift and increase compression dampening.)
I figure if I go with the compressor, I can skip the "ultimate" bags with the internal bump stop as the compressor can be set at 5 psi to keep the pressure up all the time.
Daystars seem to be a no brainer.
As far as I can tell the Firestones are similar Air lift 5000 and more expensive so it seems Airlfit is the way to go. (Hellwig aren't compatible with the daystars and have tire clearance concerns with wider tires)
Anything wrong with the plan?
Re: Logic Check -- Airbags
Post by olyelr » Mon Nov 13, 2017 11:04 pm
Sounds good to me. But, why not spend a little more money for the ultimate kit with the internal bumpstops and then not have to leave any air in the bags? Is there a benefit to not having the bumpstop and in return having to keep a little air in them (other than a bit cheaper)?
I am eyeballing up that compressor kit, too. Damn it would be handy.
ramv
Post by ramv » Mon Nov 13, 2017 11:15 pm
So the question is there an advantage to the bumpstop? I am huge proponent of air bumps, which I feel the air bags would be closer to (although relying on shocks for dampening) than the bumps on the Ultimate bags. (assuming pressure is retained).
I swapped bumpstops out on all my previous trucks and there is a lot of advatnages over the hard stock or aftermarket ones. I don't have a lot of data on the Air Lift but suspect at low speed the improved up travel would be preferential ?
israelstanage
Post by israelstanage » Mon Nov 13, 2017 11:57 pm
I went with Firestone bags because the guys selling them recommended them over the air lifts. Not sure there is much, or any, difference. You will love the remote controlled on board air. It's ballin.
Post by DamageWagon » Tue Nov 14, 2017 6:59 pm
Air bumps and air bags used as a bump cannot be compared, they're in different universes. An air bag with 5psi isn't going to do much if you bottom hard. The higher the pressure the more it helps and the more it hurts your ride. Air bags with internal bumps will give you the best ride while performing as a bump, but are more costly.
BoldAdventure
Post by BoldAdventure » Tue Nov 14, 2017 7:07 pm
Why even get his coils for the rear man? Do the front, tell Don and keep the factory rears. Still works with the Kings, pretty much my setup.
Post by olyelr » Tue Nov 14, 2017 8:06 pm
The only thing I can think is if they are indeed a little softer, maybe they ride a little better and function a little better (for empty DDing and unloaded off roading, anyway). Then, when it is time to tow or load up the bed, air up the bags....
BoldAdventure
Post by BoldAdventure » Tue Nov 14, 2017 9:23 pm
I'd love to test them, but if they're like the fronts, I bet they aren't actually softer. The other comment made to me was they are actually .75 shorter than the PW rear coils. I just recently added a rear spacer to solve my squat.
ramv
Post by ramv » Wed Nov 15, 2017 8:03 pm
Got it. Thanks for the clarification. Hence the need for the thread!
Thanks,
Post by DamageWagon » Wed Nov 15, 2017 8:57 pm
Now to clarify further, and maybe this is a Toyota thing, but I have two friends with prerunner Tundras running the full Deaver or Camburg leaves out back, and they use their air bumps as air bags hahaha. So they bring all their camping gear or whatever and the truck says until it rides on the bumps and they call it good!
ramv
Post by ramv » Fri Nov 17, 2017 12:58 pm
Awesome
Post by TankerZak » Fri Nov 17, 2017 11:04 pm
That's why i did the Airlifts with the internal bumps. Also, firestone put out something saying they weren't rated for daystar craddles.
