Western Ultramount II 8.5 on '13 PW
bones
Post by bones » Fri Oct 20, 2017 4:04 pm
Just in case anyone wanted to see how its mounted with no winch removal. 2013 PW, 8.5' Western ProPlus with the Ultramount II system. I don't see any modifications other then cutting half of the ears off each of the Western brackets (pictured with yellow arrows). It looks like they may use a new cast part for the winch mount?
2013 Laramie Power Wagon
'03 Kawasaki Prairie 650
bones
Re: Western Ultramount II 8.5 on '13 PW
Post by bones » Fri Oct 20, 2017 6:41 pm
Some pics with the plow on.
bones
Post by bones » Sat Oct 21, 2017 11:14 am
Put the air dam back on..
Post by olyelr » Sat Oct 21, 2017 11:18 pm
Heck yeah. Dont see many pw’s with a plow.
bones
Post by bones » Sun Oct 22, 2017 11:31 am
That's because the owners manual and Ram recommend not putting a plow on it.
Post by olyelr » Sun Oct 22, 2017 9:06 pm
They don't recommend having a truck camper installed either, but people still do it.
Im sure its just because of the relatively soft suspension.
bones
Post by bones » Tue Oct 24, 2017 8:11 am
Yes, its over the FGAWR of the front axle. Good read on FGAWR and it's affect here: http://info.bossplow.com/Blog/bid/15397 ... plow-Truck
yooper68
Post by yooper68 » Tue Oct 24, 2017 8:59 am
bones -
that is a nice setup; doesn't look like plow undercarriage/mount will be much of a problem for off-road. The old ones sure were....
I have seen only a few pictures of Power Wagons with plows. Red's Auto in Ironwood, MI had a 2014 or 2015 with a boss plow for sale several months back but I only saw pictures.
Good luck with the snow plowing! It's always fun ;)
Trucks: 2003 4x4 Dodge 3/4 ton, 1972 4x4 Ford 3/4 ton (factory hi-boy), shopping for new Power Wagon (or may wait for 2020 model? - 75th year special edition?)
13BlkPowerWagon
Post by 13BlkPowerWagon » Wed Jan 10, 2018 12:39 pm
Sorry to revive an old thread... The Western looks like it fits nice. I'm going to be installing a Boss on my '13 within the next couple of weeks... Thinking the passenger side support bar may interfere with the smartbar, and require some cutting/welding (not a huge deal, but a PITA nonetheless).
How difficult was the wiring harness to install (if you did it yourself)? Without the Plow Prep, I guess it's tougher (not even an option on the PW). Couple thread's I've seen on it look like most guys just wire up the plow lights totally independent from the factory headlights, which might be what I end up doing.
bones
Post by bones » Wed Jan 10, 2018 1:20 pm
I did not do the install myself, there is a local shop that is familiar with PW's and does them in less then a day. I don't think there are any issues without the plow prep, I think everything is still plug and play, at least with the Western harness it is.
Still have not plowed with it yet... not enough snowfall here in NE PA to have used it yet.
yooper68
Post by yooper68 » Wed Jan 10, 2018 5:18 pm
Wow, that's funny that you have not plowed snow yet! I've plowed at least 15 times so far this "snow season" - those snow piles in background are 8' high! Interested to hear how the PW works out for you for snow plowing.
bones
Post by bones » Wed Jan 10, 2018 5:53 pm
:D I have plowed, just not with the truck. Every "storm" we had so far was only about 2-3" each in snowfall. So I use the ATV for that, otherwise I'd have everything all ripped up.
13BlkPowerWagon
Post by 13BlkPowerWagon » Wed Jan 10, 2018 7:18 pm
Nice. We've had plenty of snow this season, and cold... but not with 50*+ days, I was hoping to get the mount on with the garage door open... but it looks like it'll turn cold again just in time for the weekend, so on goes the heater and the wood stove.
Supposedly, the Boss mount fits, but I'm really worried about the smart bar. I'll update when I put it in. Probably going to do the harness one day, and the mount the next.
yooper68
Post by yooper68 » Thu Jan 11, 2018 8:23 am
Here is a few photos of a Boss plow "undercarriage" on a newer PW, this was for sale last year & I never saw it in person - photos from dealer website. The Boss setup appears to hang down a lot farther than bones' Western mount.
bones
Post by bones » Thu Jan 11, 2018 10:07 am
Definitely appears way lower in those photos, you can see how far below the air dam it is. The good thing with the Western is that it has removable receivers (not pictured on my photos). With those receivers in, it is probably a bit lower, but no need to have them in when not plowing.
13BlkPowerWagon
Post by 13BlkPowerWagon » Thu Jan 11, 2018 10:08 am
Yeah, the Boss' usually do, but the main frame is just 8 bolts that are easily accessible to remove, then you're just left with the ears that bolt to the frame that hang down, so it's not as bad.
