BoldAdventures 2015 Power Wagon Build
jpbrazill
Post by jpbrazill » Sun Sep 17, 2017 10:13 am
So with the 1.5" Hemi coils, did you have to change the front shocks to longer ones? And is it required to get a longer track bar? Forgive my ignorance, Solid front axle stuff is new to me. Lastly, are you getting any front rub. If you are are, where and what did you have to trim? Thanks!
Aurora, Colorado
MikeKey
Post by MikeKey » Tue Sep 26, 2017 3:57 pm
olyelr wrote: When you say 1.5" hemi coils, are you talking about the coils that are 1.5" over the stock power wagon height or 1.5" over a regular 2500?
Also, how is the 4.10's working with the 37" mt's?
Thanks!
The Thuren 1.5 Coils ->> https://www.thurenfabrication.com/produ ... s-212.html That's over a stock Power Wagon.
4.10's are fine for the most part. You notice the tires more above 7k altitude on inclines, however. Otherwise, no problems.
jpbrazill wrote:So with the 1.5" Hemi coils, did you have to change the front shocks to longer ones? And is it required to get a longer track bar? Forgive my ignorance, Solid front axle stuff is new to me. Lastly, are you getting any front rub. If you are are, where and what did you have to trim? Thanks!
Nope.
Rub on front sway bar at full lock only.
Post by olyelr » Tue Sep 26, 2017 6:35 pm
MikeKey wrote: Nope.
No rub on the lower back corner of the front fender flares?! Crazy!
I may have skipped by it, but are you still using the factory rear coils or Thurens?
Hammerballs
Post by Hammerballs » Tue Sep 26, 2017 10:13 pm
He is running the stock rear coils because he tows an Airstream.
MikeKey
Post by MikeKey » Tue Oct 17, 2017 1:24 pm
So I decided to start a VLOG about our adventures and our Power Wagon build. Just put together this first video from a trip out to Indian Springs this weekend.
phpBB [video]
Clickable link for Tapatalk
Post by olyelr » Tue Oct 31, 2017 11:58 am
Very cool video’s MikeKey. :cheers:
I wish I had the knowhow to produce video’s like that. How long does it take you to whip out a few minute video like that (not including film time, just actual time puting it together)? And what program do you use?
MikeKey
Post by MikeKey » Tue Oct 31, 2017 2:29 pm
Thanks. :cheers: That was done with Final Cut Pro X - I have Premier thanks to work, but Final Cut was a lot easier to learn and just start editing. That took maybe and hour and half of me screwing around with it. Setting it to music and what not. I have just watched some youtube videos out there for ideas and I've always been self-taught. Very good at seeing and copying.
Post by coder » Tue Oct 31, 2017 4:21 pm
Hello MikeKey, great video, I really like what you've done with your PW and that wide open country, not a tree in sight!
Post by olyelr » Wed Nov 01, 2017 11:11 am
Geez, that sure doesnt seem like much time to put a vid like that together. With music cutting in and out with you talking... all on que, like when the tire hits the mud puddle... impressive! I'm gonna have to start youtubing that stuff and see if I can figure it out.
Maybe I missed it, but how are you liking the 37's with the stock gearing (off road, towing, and daily driving)? Obviously 4.88's or 5.13's would be better, but is it acceptable the way it is?
Chubbs
Post by Chubbs » Wed Nov 01, 2017 11:35 am
Reminds me a lot of Ronnie Dahl. That is not a bad thing.
2018 Power Wagon
Woodscavenger
Post by Woodscavenger » Sun Nov 12, 2017 11:37 pm
Great build thread. I am in Boise as well. Interested in your bumper, headache rack and the Ham radio install. Will send you a PM.
Idaho RC
Post by Idaho RC » Mon Nov 13, 2017 1:47 pm
I am in Boise as well. I have seen MikeKey truck running around town a couple of times. Its easy to spot that snorkel.
MikeKey
Post by MikeKey » Mon Nov 13, 2017 4:28 pm
And.... why are none of us hanging out? :poke:
Post by olyelr » Fri Nov 17, 2017 10:25 pm
:bump:
update time
MikeKey
Post by MikeKey » Sat Nov 18, 2017 12:03 am
It’s winter, what more do you want to know? I rotated my tires and changed my oil last weekend.
Post by olyelr » Sat Nov 18, 2017 7:58 am
Maybe you could let us know how you got your oil filter off.
Post by Colibri » Sat Nov 18, 2017 9:29 am
Usually a little dirty talk first, then he just screws till he gets it off :rofl:
MikeKey
Post by MikeKey » Mon Nov 20, 2017 4:36 pm
I put 1-inch spacers on top of the rear coils. Forgot to mention that. :p
Woodscavenger
Post by Woodscavenger » Tue Nov 21, 2017 12:51 am
Mike, check you private messages. I sent you a couple of questions.
MikeKey
Post by MikeKey » Tue Nov 21, 2017 1:01 pm
I don't think you did, I have nothing new in my inbox on the site here. :cheers:
MikeKey
Post by MikeKey » Wed Nov 22, 2017 10:07 pm
Highlight reel from our most recent VLOG of just the Power Wagon wheeling in the snow up at Stanley Lake in Stanley, Idaho, along with a recovery and my thoughts on our 37-inch Toyo Open Country MT's in the snow.
phpBB [video]
Post by TwinStick » Wed Nov 22, 2017 10:43 pm
? Former upstate NY'er ? Where abouts ? I am a Western NY'er. Buffalo area. Great vids
Post by olyelr » Wed Nov 22, 2017 11:36 pm
A Toyo MT sucks in the snow... BLASPHEMY!
Love the vids too, keep em coming :cheers:
Post by olyelr » Wed Nov 22, 2017 11:41 pm
And you look to be missing a lug nut...
MikeKey
Post by MikeKey » Thu Nov 23, 2017 12:55 pm
Yup :doh:
Syracuse
